3rd gen lift... OME, Kings, SAW..... uggg even more confused now....
Old Jan 26, 2004 | 09:31 PM
socal98runner's Avatar
Ok, so I've read and read and read some more.....
Does it get any easier????
Yes, I know... I'm a noob... Help me make the right choice so I don't waste my time and money.
So, here's what I got so far.
98 4x4 SR5 = my truck
I want a smooth ride, I sold my lowered Honda for a reason.
Here's what I've chosen so far.
All OME stuff
N91SC front shocks
881 front coils
10mm spacers in front
N86C rear shocks
890 rear coils
1" transfer case spacers
From everything I've read, this is a comfortable ride, still allowing me to tow something light (2000lbs).
Ok, where to get the best prices on OME (yea, I searched)
what swaybar disconnects are worth while???
Anything I'm missing?
Thanks!
Old Jan 26, 2004 | 10:01 PM
RobT2k's Avatar
I got my OME stuff from Mike @ xtremeoff-road.com he's a member on here and does alot of group buys for us too.
I got my disconnects from Lars Dennert. You probably don't need them right away, go with us a few times offroad. You said you were going to take it easy for a while. I just got my disco's this month and I've been taking my 4Runner on some pretty rough trails for over a year without them.
Old Jan 26, 2004 | 10:32 PM
Good Times's Avatar
Try doing some homework here:
http://fastq.com/~sschaefer/recommend.html
Steve is a member here and he has a wealth of info for your 4runner!
Good luck
Old Jan 26, 2004 | 10:36 PM
Tacoma Dude's Avatar
In case you were wondering you can reach Mike by PM here he goes by XtremeOff-Road or you can check out his website http://www.xtremeoff-road.com OR you can call him on his cell phone. If you do a search on Mike and cell phone I'm sure it'll come up.
You may want to check some of the for sale sections of several sites TTORA, 4x4wire, etc, etc...
Old Jan 27, 2004 | 03:48 AM
jacksonpt's Avatar
Senior Member
Definitely give Matt Peters a call at Peters Offroad. Mike's prices will probably be slightly better, but no one can tough Matt's customer service. I bought my OME gear from him, and I'd go back to him in a heartbeat.
Old Jan 27, 2004 | 04:34 AM
waskillywabbit's Avatar
OME
I just replaced all my OEM stuff with OME
Front:
881s and N91Ss
Rear:
891s and N86s
My hiney is slightly higher than my front, but when I tow it levels out quite nicely even heavily loaded, so I'm happy.
For some help on installing all this stuff yourself, check out my webpage and go to the write-ups section. I have details on installing the OME stuff.
You can't go wrong with the OME stuff. You've made a wise choice. You will sit a little more even that I do, and your ride will be a little softer, but you will still be able to tow with only a bit of sag in the rear. My 4Runner rides much better and has much less body roll in turns than before. If I had known about the much better ride with the OME stuff before I would have done it sooner.
Don't forget the diff drop kit to lessen the angle on your CVs. You can buy one or just make on from some longer bolts and washers. Do a search to find out how.
Good luck!
Old Jan 27, 2004 | 05:06 AM
goldtaco9's Avatar
Re: 3rd gen lift... OME, Kings, SAW..... uggg even more confused now....
Originally posted by socal98runner
.......................................So, here's what I got so far.
All OME stuff
N91SC front shocks
881 front coils
N86C rear shocks
890 rear coils
1" transfer case spacers..............
That is close to where I am going but without the spacers. I am working with Mike @ Xtreme. I have both 890 and 891 coils coming as I am very concerned about a rough riding 4Runner and I will be testing both. If I can get away with the 890's for daily driving, I will get airbags that I can use for when I tow.
I also have a TJM on order (any second now) from Mike.
I agree with you that this has been the hardest thing to figure out without driving a few examples of each set-up.
Mike
Old Jan 27, 2004 | 05:10 AM
OME
You guys won't be disappointed and I'll say it again, my OME stuff made the ride MUCH better!
Old Jan 27, 2004 | 07:15 AM
RTdawgs's Avatar
get 2.5" front spacers with OME N91S struts and rear OME 890 coils and N86 shocks.
this way, youll lift it once and be level.
Old Jan 27, 2004 | 08:27 AM
OME N91S shocks and 891 springs, is that what you meant to say, AND a 2.5" front spacer? That'll put the front up over 3" won't it which ain't good for the CVs? Pleeez splain...
Old Jan 27, 2004 | 11:23 AM
RTdawgs's Avatar
front: stock coils, 2.5" lift spacer and OME N91S struts.
rear: OME 890 coils and N86 shocks
Old Jan 27, 2004 | 12:35 PM
goldtaco9's Avatar
This probably belongs in it's own thread but.....
I just placed my order for OME's (front & rear) and a TJM from Mike at Xtreme. The countdown begins......................
Mike
Old Jan 27, 2004 | 08:32 PM
Good luck
Lance - THANKS!!!
That was some GOOD reading!!! Now I am closer to making my choice on what OME I end up with.
Old Jan 27, 2004 | 09:08 PM
Good Times's Avatar
np!
If you need help installing them, setup a post called "San Diego Wrenchathon!".
Make sure you post what you want installed. Make sure you have ample space to get the work done and also make sure you provide some grub! Lots of members here are very friendly and will have no problems showing up at your doorstep to give ya a lending hand.
This way you meet some of us and also learn more about your own truck
Old Mar 17, 2004 | 05:43 PM
XtremeOff-Road's Avatar
Hey I was just going through some old post and saw this....Were you not pleased with the service you received. Please let me know...we can take care of it off-line @ michael@xtremeoff-road.com
Mike
Old Mar 17, 2004 | 07:59 PM
keisur's Avatar
that's up in the air. I put mecatech boots on the outers and I haven't had any complaints since then from the cv's. the inners are stock as mecatech is too lazy to make the correct inner boot. I've been at 3" infront since I dropped in the 4.88's and the ARB lockers. and no problems as of yet. and also no vibrations since the diff drop. It's probably my SAWs the absorb the vibes if there are any {just kiding and SAWs are the way to go in my opinion.
Old Mar 17, 2004 | 08:18 PM
Birdman's Avatar
Mike
LOL
Old Mar 17, 2004 | 08:44 PM
Originally Posted by Birdman
LOL
I am missing the joke??? :wtf:
Mike
Old Mar 18, 2004 | 10:52 AM
goldtaco9's Avatar
Mike
Me too. I ordered from Mike on 01/27 and the TJM was home 02/02. The OME's arrived 02/09 and I had the whole kit-n-kaboodle customized and installed by 02/27. Not too shabby IMHO.
Mike
terminator
Oct 13, 2021 10:13 AM
nvdesertrunner
May 11, 2020 08:18 PM
39 Thieves
Jan 6, 2017 01:08 PM
digitalracer
May 16, 2016 03:57 AM
Corvoid
Sep 15, 2015 07:24 PM
