3rd gen. license plate lights dead
Old May 28, 2005 | 10:53 PM
tgreathead's Avatar
I just realized my license plate lights are dead. I pulled off the hatch panel and checked all the connections and all fuses related to the hatch. Everything seems proper but they won't light up (and yes, I replaced the bulbs just in case)
Any ideas?
Old May 28, 2005 | 11:06 PM
jimbo74's Avatar
reverse switch o nteh tranny?
Old May 30, 2005 | 12:45 AM
tgreathead's Avatar
I honestly have no idea what that means
Old May 30, 2005 | 04:38 AM
MTL_4runner's Avatar
Why would those be hooked into the reverse switch?
You may need to get a multi meter to check for voltage on the wire.
Worst case you can run a new power wire from the tail lamps to the LP lights to make em work again.
Old May 30, 2005 | 05:32 AM
waskillywabbit's Avatar
I think Jim misread...but answering every post on Yotatech has to be an daunting task!
Old May 30, 2005 | 06:35 AM
lee's Avatar
lee
Old May 31, 2005 | 02:09 PM
paranoidandroid's Avatar
make sure your headlights are on when u check. I thought mine were dead and spent 3 hrs trying to diagnose before i realized that they come on when the headlights come on.
Old May 31, 2005 | 02:15 PM
jimbo74's Avatar
i swear it said reverse lights before......
Old May 31, 2005 | 08:31 PM
tgreathead's Avatar
Ya, I almost did the same thing but they still don't come on with the headlights. I tried jiggling all the wiring right under the hatch panel and still nothing. I'm a little wary of pulling out a bunch of stuff to get to the wiring. I may just take it in somewhere and have them check it out.
Old May 31, 2005 | 08:37 PM
jimbo74's Avatar
be cautious of takign ti somewhere.... electrical diagnosis is one of those areas where a shady shop will charge you for 3 hours, do nothing (not even touch the car) and say they tried and still couldnt find the problem..... then not much you can do at that point except pay them, if you refuse, they can lien hold your truck!
Old May 31, 2005 | 09:03 PM
tgreathead's Avatar
What do you suggest?
Old Jun 1, 2005 | 10:05 AM
all your fuses are good right? if they are, get a multimeter, and see if you are getting a reading inside the bulb socket. standard voltage on cars is ~12V i think (correct me if im wrong) also, see if u get a reading at the fuse block. if you are getting a reading at the block but not at the bulb socket, then u know the problem is between the block and the bulb. just keep working your way towards to the lights, and you will prob run into a bad connection or something.
Old Jun 1, 2005 | 10:58 AM
At the very least you can pull off the interior panel for the hatch and have a look in there. That will give you enough room to probe the wires for power. You may also need to pull down the headliner to get access to the wires further up inside the truck.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
