Last edit by: IB Advertising
Browse all: Toyota 4Runner Brake Guides
- Toyota 4Runner 1996-2002: Brake Modifications
Overview of popular modifications to help you customize your 4Runner.
3rd Gen Brake Upgrade - No more warped rotors
#63
Originally Posted by bamachem
nope. the 16's on the runners have different rotors and calipers than the 15" runners.
If they did then as Bamachem said, they would definately have different rotors too.
I wonder if those are the larger calipers they added for the TSB or just a change from model years.
#65
Originally Posted by drbeau
Now it would be nice if you could reuse the old brakes for a rear disc conversion of some kind.
#66
Originally Posted by Alin10123
That might be hard to do. Since disc brakes require more pressure to work just as effectively as drums. You will actually loose some braking power to the rear since the rear system has the pressure calibrated for drums. Now i'm sure if you had a lof of time and money, that this conversion can be done effectively and right. Otherwise, if you simply do a direct bolt on drum to disc conversion, i dont really think you are accomplishing very much.
but first thing that comes to my mind is a proportioning valve or valves,
depending on number of lines - they are not that expensive...
#67
Originally Posted by schlopecki
I don't know how much would it cost to do it really, really right,
If you don't put one in, you will be guaranteed to lock up the rears the first time you try them out.
#69
Originally Posted by MTL_4runner
I didn't know the Tundra ever came with 15" rims.
My brother has a 2003 tundra SR5 2WD that I'm 99% sure has 15" wheels. They're the fugly steel ones and NOT the alloys like on the TRD Tundras.
#73
You only need one adjustable valve for the line going to the rear brakes.
Read this post.
https://www.yotatech.com/forums/show...6&postcount=14
#75
mmmm this summer its lookin like tundra calipers painted black or red with a tundra solutions big brake upgrade to 17inch cross drilled and slotted rotors to slow down my new big wheels
#76
Calipers
Originally Posted by ColImport
they said that both 199mm and 231mm are from tundras 2000 and above, I would love to get the bigger ones but dont know if they would fit even after shaving the dust cover?? any pointers?? MTL? thanks for your help!
#79
Originally Posted by 2.7tacoma
What about the brake booster and master cylinder, do they need to be upgraded to the Tundra?
The upgrade for the rotors and calipers was to prevent warping of the rotors. So if you wanted to replace your master cylinder to a Tundra's you could. But you dont have to in order for this mod to work.
#80
Originally Posted by tundra8
I believe the 199mm were the calipers used on 2000-2002, in 03 they replaced them with 231mm. The 00-02 Tundras have alot of break problems (vibration) so a tsb was put out by Toyota replacing them with 231mm. I don't think the size matters on a 4runner as long as they fit without much shaving.
4Runners don't weigh as much so either of those should be an improvement over stock.
