3rd Gen Audio Question
Old Jan 11, 2003 | 04:12 PM
Vato Loco's Avatar
This friday coming up Im getting my audio system installed. I have the limited with the cd, cassette and radio deck, question is, does the cd player have the brackets, or would the installers have to order it?
http://www.crutchfield.com/cgi-bin/S...176T21&o=m&a=0
Oh and its 51/4 for the rear doors with no mods right?
thanks
Old Jan 11, 2003 | 04:18 PM
PhxTRDRunner's Avatar
Rear doors should be 5 1/4's ( I haven't changed mine out yet ) and you will need no additional brackets, however you will need a toyota pocket to go underneath the radio (assuming you bought a single din unit) since your factory is double din. You also have a factory amplifier underneath the factory radio that will simply unplugged to bypass it (takes less than a minute).
Good luck, hope it turns out good!
Old Jan 11, 2003 | 04:22 PM
Vato Loco's Avatar
Im not going to need that pocket no more because I am installing an equalizer right under the single DIN unit Thanks for the goodluck, I hope it turns out good.
Old Jan 12, 2003 | 10:48 AM
Vato Loco's Avatar
Anbody want the factory CD/Tape/Radio deck for a reasonable amount after it has been removed from the rig. The rig will go in this friday and hopefully be out by the end of the day, just lemme know. thanks
westside@mountaincable.net
Old Jan 12, 2003 | 11:50 AM
How much?
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
93toyoguy
Aug 2, 2015 07:41 PM
vanion2
Jul 29, 2015 06:17 PM
