3rd cyl misfire code
Old Mar 27, 2004 | 01:02 PM
96TRDsc's Avatar
I got a 3rd cyl misfire code Which cyl is the 3rd cyl so I can check the plugs and wires??? The boot on the plug on the driver's side closest to the firewall was loose...I'm wondering if that might have made a bad connection and killed the wire....I seemed to have misplaced my 4Runner manuals....
I'm hoping I just need plugs and wired...maybe injector cleaning
I also got a "system running lean" code...but believe that was due to a split hose (that was going to the boost gauge)
Thanks in advance,
Old Mar 27, 2004 | 01:15 PM
Dr. Zhivago's Avatar
Away
A vacuum leak can cause a misfire code to appear, FYI. But, to answer your question about which cylinder is which, #3 is the middle cylinder on the Passenger side.
The cylinders are laid out like so:
--(Firewall)--
5 --------- 6
3 --------- 4
1 --------- 2
--(Radiator)--
Hope this helps
G
Old Mar 27, 2004 | 04:18 PM
96TRDsc's Avatar
Thanks I have repaired the split hose...I need to replace the plugs/wires anyway I will clear the codes and see if everything is fine.....
Thanks again,
Old Apr 7, 2004 | 06:09 AM
96TRDsc's Avatar
-= UPDATE =-
I replaced the split hose....replace the spark plugs (Thanks Gadget!) and cleaned the MAF and it drives fine now
The plugs were the stock style platinum, now they are Denso 2 step colder plugs (from Gadget)...and I dont think I have EVER cleaned the MAF (and I have 133k miles now)
Anywayz...all is well in supercharger 4runner land now
jerusry
Oct 19, 2015 05:28 PM
bobpat
Sep 1, 2015 07:25 AM
pyramid
Jul 30, 2015 10:05 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
