34 versus 34r?
Old Mar 29, 2007 | 05:27 PM
r854rnr's Avatar
34 versus 34r?
What have those of you with a series 34 done to remedy the battery cables? I figured it would be a straight up change. Looks like it it is a custom oem wire harness. So, any write ups or pictures or good descriptions of what I can do to make the 34 work? (it does have the side "posts" if that matters.)
Old Mar 29, 2007 | 06:34 PM
BruceTS's Avatar
Assuming your talking about a Optima battery, I had to re-route the white wire in the fuse box so the cables could reach the terminals. I also re-bent the top battery bracket, rather than using the spacer under the battery.
Old Mar 29, 2007 | 06:43 PM
xcmountain80's Avatar
I turned my yellow 34 on its side terminals facing firewall bottom facing bumper and thats that.
Aaron
Old Mar 30, 2007 | 02:58 AM
hiloracerboy84's Avatar
i did the same as xcmountain and all the stock wires reached. since then ive upgraded wire size tho, which was easy so it doesnt matter what u do with it
Old Mar 30, 2007 | 03:32 AM
The pain in the ass was of all the auto stores here in Orlando none of them carry the R series and they look at me funny when I ask for it. So I figured well duh they can be mounted this way and that right on.
Aaron
Old Mar 30, 2007 | 03:40 AM
pat161's Avatar
I third the above response, just put it on its side and be done. Worked fine for me.
Old Mar 30, 2007 | 02:39 PM
BruceTS's Avatar
This is how mine looks now.....
Old Apr 2, 2007 | 09:50 AM
r854rnr's Avatar
Where did you move the reservoir?
Cycles
Sep 29, 2015 06:37 AM
alotawatts
Mar 20, 2006 03:38 PM
Jeff_M
15
Dec 6, 2005 07:35 PM
jimrockford
Oct 2, 2005 04:36 PM
