33's...what gear ratio to go to?
Old Mar 3, 2003 | 06:31 PM
Mudd Runna's Avatar
O.k...I'm alittle confused....my runner is basically a daily driver with the occasional offroad it sees...I'm running 33's under it and I just found out that my 88 came stock with 4:10's...but I want to regear to regain some lost ponies....but what to regear to? 4:56's or 4:88's? Pros and cons anyone?
Old Mar 3, 2003 | 06:39 PM
CTB's Avatar
CTB
4 cyl or V6?
Old Mar 3, 2003 | 06:42 PM
toyota parts dude's Avatar
4.88
this is toyota parts dude i recomend the 4.88. i have the 5.29 gears in my 82 when i 1st put them in i had 33's and they wre a little to low with the 35's i got now it about rite like a stock truck. the 4'88 should be graet for. you just my opinion.
Old Mar 3, 2003 | 07:12 PM
Salue's Avatar
Mine came with the 31's from the factory and I have 4.88's, so I think I am going to try to stuff 33's with as little lift as possible.
Salue
Old Mar 3, 2003 | 07:20 PM
Cebby's Avatar
Salue
Me, too (4.88). I have 32's now. The next step is the 33's. Same deal, not much lift - just enough to squeeze them in...
Old Mar 3, 2003 | 07:40 PM
decepticon's Avatar
how much lift do you need to fit 33? i have 32 with a 2' life. wil that work or do i need to go higher?
Old Mar 3, 2003 | 07:57 PM
CTB's Avatar
CTB
Man, you have a 2' lift?!?! I'd like to see pictures of that...
Old Mar 3, 2003 | 08:35 PM
Salue's Avatar
Cebby,
How are you planning on getting the 33's to fit? Do your 32's rub at all right now?
Salue
Old Mar 4, 2003 | 02:53 AM
decepticon's Avatar
i was able to fit my 32 on factory setting, however i got rub whebn the wheel was almost turned fully, under a hard break, it would rub, hit a big bump, like a speed bump, it would rub.
Old Mar 4, 2003 | 03:01 AM
ringo234's Avatar
I have 32" AT's on my stock suspension It hasn't rubbed yet.
(94 4Runner/Auto w/4.88) just right gearing.
Andy
Old Mar 4, 2003 | 04:08 AM
Cebby's Avatar
Cebby,
Salue
My 32's don't rub. (Nor did they rub with full tread. I have the PP coils in the back and stock T-Bars currently. If I keep my stock wheels and add a Roger Brown 1" bodylift, I should fit with a little seam pounding. I want to go to a 15 x 8 wheel though, so I'm not sure what that will do to clearance.
Old Mar 4, 2003 | 04:36 AM
keisur's Avatar
I have 33's and a SAW/OME lift combo for around 2.5" average lift. mine will only slightly rub when fully turned to the right and I hit a bump like a speed bump or offroad or turning from a high parking lot onto a lower street, only slight rubbing thought I I could probably just bend something or trim a piece of plastic because it's plastic that the tire hits. only the drivers tire. oh yea, I would recommend 4.88's, that's what I'm going to when money permits.
Old Mar 4, 2003 | 06:02 AM
Mudd Runna's Avatar
Lift for 33's
Well I have 3" body lift and a 4" suspension lift that clears the 33"s just fine...although I could run 35"s with no problem....
Old Mar 4, 2003 | 07:43 AM
rabidbeaverbaby's Avatar
gear table
i don't know if anyone mentioned this but at www.4lo.com they have a gear/tire size table that might help......from the table it looks to me that 4.88 gears with 35'' tires would give you more power but prob less gas milage and the opposite for 4.56....so i guess it just depends on what you want....hope that helps
Old Mar 4, 2003 | 08:15 AM
keisur's Avatar
Re: gear table
I have 33's and 4.10's and that chart shows them on the low end of "ok." I have noticed since going to 33's I have less power and get worse gas mileage.
Old Mar 4, 2003 | 08:56 AM
RTdawgs's Avatar
Re: Lift for 33's
if youre ever think youre gonna get 35s, get 4.88s.
Old Mar 4, 2003 | 09:50 AM
Here ya go!!
4 cyl
31's = 4.10
33's = 4.88
35 and bigger = 5.29
V6
31's = 3.73, 4.10 if you tow alot. (or whatever stock Toy's use)
33's = 4.10
35's = 4.88
37's+ = 5.29.
This stuff is what I have seen to be the most used combos.
Old Mar 4, 2003 | 10:05 AM
Churnd's Avatar
Go 4.88's. 5.29's are too low for daily driving. Plus 4.88's are a more durable gearset so they'll last you longer. the only exception to this is if you have a 4cyl and you might go up to 35's. In that case stick with your gears you have now and re-gear when you get the 35's.
Old Mar 4, 2003 | 12:56 PM
Flygtenstein's Avatar
Engine and transmission go a long way in figuring this out.
If you are going to go to 35's, then 5.29's would be worth a look if you have the stock transfer case.
If you are going to stick with 33's, have a 5 speed, have a V-6, or plan to add dual cases, then 4.88's should be fine.
I have 5.29's with 33's behind a V-6 with an auto. I can easily do 75 while still getting good mileage.
Throw those calculators out the window, they only deal with diameter, not increased mass or rolling resistance.
Old Mar 4, 2003 | 08:05 PM
decepticon's Avatar
ok what is happening when i switch to a lower gear? Is it making less effort for the motor to spin oversized tires? Does going to a lower gear affect top speed? also is it ok to use 4wd if i just change the rear diff to 4.88?
