300k Miles+ - Proper Maintenance for Older Toyotas
Old Nov 28, 2008 | 11:55 AM
kford's Avatar
As so many other loving Toyota owners do, I refuse to give up on my 1997 4Runner 4wd SR5 without a fight. I have replaced radiators (7+), alternators, and most recently had a crank shaft bolt break.
My '97 4runner now has 324,000 miles and it's running better than ever. Original 3.4 engine, origianal transmission, etc. etc.
As a paranoid individual, I feel like I'm neglecting some crucial maintenance that may lead to my vehicle's demise.
Outside of regular fluid changes (oil, transmission, diff.'s, x-fer case, etc etc), regular maintenance (spark plugs/wires, air filter...) what can I do to keep my 97 running as great as it is?
Thanks and feel free to tell about your own Toyotas that refuse to die.
Old Nov 28, 2008 | 12:11 PM
desertcox05's Avatar
i also have a 89 truck with 296,000+ mi. It has also been used to teach my 3 boys how to drive a standard. the only thing more i can think of is regular sensor replacement. how reg., idk
Old Nov 28, 2008 | 02:32 PM
DailyDrive's Avatar
did you change the origianal lube in the transmission?
Old Nov 28, 2008 | 08:40 PM
Meterpig's Avatar
How did you rack up 300K?
Wow!
Old Nov 28, 2008 | 10:16 PM
Ohio4R's Avatar
Lube the u-joints, steering rack bushings, shocks, check for oil leaks behind the heads and crank.....
TURBOrunnerNM
Jul 22, 2015 11:01 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
