3.90s with 35s
Old Apr 2, 2010 | 09:38 PM
  #41
brian2sun's Avatar
Looks awesome. Definitely looks like you'll have some fender trimming to do.
Old Apr 2, 2010 | 11:00 PM
  #42
elmerfudd_22's Avatar
Its fine flat, except cranking it around the corner, defintly not seeing much rough terrain though untill I do some trimming/body lift
pictures cant even describe how nice these tires are, and theyre quiet too
Old Apr 3, 2010 | 07:01 AM
  #43
Fink's Avatar
I told ya man, those are the best mud tires out there as far as I am concerned.
They will be the next set I get for my Tacoma when my MTZ's wear down.
Fink
Old Apr 3, 2010 | 07:16 AM
  #44
GranVille-4crawler's Avatar
5.29s are a perfect match for 35s my buddy is running the same setup on his 85runner. Not the best for interstate travel but he can actually accelerate in town not have to ride the slow lane like I do lol amd I have stock 4.10s. I have the km2s and love em!
Old Apr 3, 2010 | 09:36 AM
  #45
From what ive researched 5.29 is nice but 4.88s would be a closer ratio to stock on the 3.4.... 5.29s for the 22re though
Old Apr 3, 2010 | 11:00 AM
  #46
Fink's Avatar
I agree - 4.88's will be your best choice.
Fink
Old Apr 3, 2010 | 11:08 AM
  #47
yotaman85's Avatar
looks good man..get some flared fenders. for the front and call it good, maybe some bushwhacker cut outs for the back.
Old Apr 3, 2010 | 11:14 AM
  #48
brian2sun's Avatar
Fink
X3. For a 5 speed, 4.88s will be great. I have 4.88s and 33s and it's perfect for an auto IMO.
Old Apr 3, 2010 | 05:34 PM
  #49
yes it looks like im going to need some bushwackers for sure, the tires stick out about 3inches or so with the 1.25 spacer.
I found an elocker axle at the scrap yard for 550 but without the wiring so Ive gotta track that down and ill be all set to regear
Old Apr 5, 2010 | 07:58 AM
  #50
cpizzle42's Avatar
I think your problem with rubbing in the front will be on the firewall. Cut out fenders wont help you all the much. But you are running spacers, so I dont know.
Old Apr 5, 2010 | 02:58 PM
  #51
yes it is rubbing worse than I thought, not just the plasic wheel well cover but the firewall/pinch weld as you said, it even started to cut into my outter lugs. Im going to try to go pound it down right now. I need to invest in a highlift jack my floor jack wont even lift this thing anymore
Old Apr 5, 2010 | 08:28 PM
  #52
cpizzle42's Avatar
haha yeah I bought a brand new jack from sears and it's not even close to being able to lift my truck. I just cut up some 2"x4" wood sections and screwed them together to get it up, then use big heavy duty RV jacks to keep it up there. Did you end up putting that body lift on?
Old Apr 5, 2010 | 09:01 PM
  #53
I wish...it still hasnt came yet...im dying to get this thing offroad
Old Apr 6, 2010 | 05:17 AM
  #54
Fink's Avatar
Take a sawzall and angle grinder to it and you should be fine as far as the pinch weld goes.
Fink
Old Apr 6, 2010 | 11:37 AM
  #55
brian2sun's Avatar
I think if you grind that area too much, the floorboard in side the cab can practically fall out so be careful. The write ups that I've seen also re-weld the pinch weld after it's ground down.
Old Apr 6, 2010 | 01:33 PM
  #56
oh really, good to know, thanks, il try that out
Old Apr 6, 2010 | 02:57 PM
  #57
brian2sun's Avatar
Here's a page with good info on how to do it right:
http://www.trailslesstraveled.com/news.php?id=48
Old Apr 6, 2010 | 03:49 PM
  #58
Fink's Avatar
If you just cut and grind the pinch weld where it's even with the floorboard you'll be fine - I doubt you'll have to trim or cut any more than that with the body lift on there.
Fink
Old Apr 6, 2010 | 05:05 PM
  #59
cpizzle42's Avatar
I thought he was not going to do the body lift?
Old Apr 6, 2010 | 08:22 PM
  #60
Well I think I am going to do the body lift now, even though it is still not here. It looks like ill need to do ALOT more trimming without it. Im still rubbing with the wheels fully cranked just on flat ground, and I ground down my pinch weld so its even with the inner wheel well.
