3.4L V6 (5VZ-FE) Swap into my '92 3.0L (3VZ-E)w/ 5 Speed manual tranny
Old May 23, 2003 | 02:30 AM
windancer4x4's Avatar
Hello all,
I wish to inquire about your thoughts about the subject above.
Any one who tried this project could tell us his experience w/ thanks.
Any electrical areas to watch for? How about teh wiring Harness?
oil Pan fit,
I know that the front 4X4 shaft is in the right (passenger) while the collecter exhaust pipe comes from the left side in the 3VZ-FE which is the opposite of the Tacoma 3.4L location of the front shaft (goes from left-driver side)and the exhast pipe is in the passenger side (right)...
Thanks all
Zak... windancer4x4@yahoo.com
Old May 23, 2003 | 04:29 AM
Cebby's Avatar
Try these guys for the harness.
I think a T100 oil pan is needed. Reroute fuel line and some exhaust mods also.
I think a 1" body lift minimum is needed for clearance.
Old May 23, 2003 | 06:46 AM
Victor's Avatar
I've heard that you can reuse your 3.0 oil pan, windage tray, and oil pump pickup. I believe if you find a bellhousing for a 3.4 with its slave cylinder and hydraulic plumbing you won't have as many interferance problems on the passenger side of the vehicle.
Most guys route the exhaust on the passenger side and at some point have it come across back to the driver's side to the original exhaust. I wonder if 3.0 headers would bolt to the 5vze and allow the exhaust to stay on the driver side?
Someone said a 2" body lift was necesary but all the previous info is 1" is enough. This will also help with exhaust room. Perhaps a 1.5" is a better compromise than 2"? Also - has anyone looked on the front of the 5vze to see if the 3.0 accessories can be used. I'd love to see the serpentine in there but that would lead to a lot of rerouting of lines - power steering, A/C, etc.
As it is you'll have to move your fuel line but I think a shop can a shop that does hydraulic lines can fab that up.
Old May 23, 2003 | 10:17 AM
UKMyers's Avatar
Read this thread It's got quite a bit of good info. I am going to start looking for an engine here real soon for the swap myself.
Old May 23, 2003 | 10:22 AM
Highland Runner's Avatar
Check this link on pirate4x4.com. http://www.pirate4x4.com/forum/showt....0+to+3.4+swap
There is a lot of pictures etc.
Old May 23, 2003 | 10:33 AM
UKMyers's Avatar
Highland I beat ya too it!
Old Aug 14, 2006 | 11:59 PM
Oh, well..the truck is up and running now with the automatic traney from the donor 2003 vehicle!! It's still a nice 4X4...
Thanks to alllllllllllllllllllll
Old Aug 15, 2006 | 10:39 AM
Pozi's Avatar
Wow. Now that is an old thread revistited. Was the Runner down this whole time?
Old Jan 18, 2010 | 08:43 AM
BerkeleyBogger's Avatar
yall i would love to put a 5vz-fe in my 89 toyota but idfk how to do any of this.
ive been tryin to look up things about the swap but i start 2nd guessin things.
my biggest fear is to buy the 3vz-fe and go to swap and have to buy other parts.
is there any other thread with like detailed info on the swap??
thanx
Scott
Old Jan 18, 2010 | 11:07 AM
vandert's Avatar
There is a whole section on the board now for 3.4 swaps man, tons and tons and tons of info
Old Jan 18, 2010 | 12:23 PM
yodathespian87's Avatar
https://www.yotatech.com/forums/f160/
Read everything there to start. Mechanically its easy, when you get intothe wiring its a little harder but not bad. Just about done mine.
ChiefTetlow
Aug 10, 2015 04:19 AM
TNRabbit
May 8, 2009 03:43 PM
rlhd00z
3.4 Swaps
24
Feb 16, 2009 12:22 PM
914runner
Aug 14, 2006 08:11 AM
