3.4L TPS only at 75% at WOT!?
Old Apr 6, 2006 | 11:26 AM
SLC97SR5's Avatar
I noticed while using the OTC OBDII scan tool from Cornwell that my TPS is only registering 75% while at WOT. Is this the correct value? I figued it would be a linear rate...0%-100%. It reads the same weather I'm driving at WOT or with the Key On Engine Off (in ACC) and floor it. What are you other guys seeing and does anyone know what we should see? THANKS!
Old Apr 6, 2006 | 12:39 PM
AK95Taco's Avatar
I did the same thing last summer and had similar results, when I asked then I had a couple of people confirm that this is normal. In fact if you have access to the FSM it describes exactly what the acceptable limits for no throttle input and WOT are. I can't recall exactly but somewhere around 9-15% and 71-82% respectively. I think...
Old Apr 6, 2006 | 02:12 PM
midiwall's Avatar
(well there ya' go John... I was wrong!)
John had asked me this in a PM and I suggested that he ask it in the forum 'cause I wasn't sure. Good thing, 'cause I was leaning on the side that something was messed up.
Old Apr 6, 2006 | 02:27 PM
marko3xl3's Avatar
Haha I can just imagine you right now! "WHAT!?! Does that mean I could've jumped the dune higher? I am so excited!"
Just playin
Old Apr 6, 2006 | 02:32 PM
midiwall's Avatar
Just playin
Dude... I already had the SC in that pic - the first jump was PLENTY high.
(oh wait... you know this from the other thread... n/m!)
Old Apr 6, 2006 | 02:36 PM
marko3xl3's Avatar
But, but...the TPS was only going at 75%!!!
Yeah, I am pretty sure that jump was high, looks high in the pics! I wish I was there to see it in real life, whew!
About the TPS thing (so I would actually be productive in this thread), I think it's because the throttle is at 100%, but the TPS is only at 75% because it could go more if it's attached to a different car and whanot.
Old Apr 6, 2006 | 02:51 PM
GSGALLANT's Avatar
For reference, my 2002 FSM (for 3.4L 4x4) says:
No throttle = 8% - 20%
WOT = 64% - 96%
Pretty wide acceptable ranges!
Old Apr 6, 2006 | 08:53 PM
SLC97SR5's Avatar
Thanks alot guys, according to the FSM it makes sense, since the closed throttle value is essentially making up the difference @ WOT.
GSGALLANT, you need to get movin' on your dual batt setup...I'd love one but can't find the space with my current setup! Thanks again.
Old Apr 6, 2006 | 09:58 PM
yoda-g2's Avatar
Ok, this makes me feel a little better. I was getting the same results and thought my tps was out of whack.
Old Apr 11, 2006 | 04:14 AM
MTL_4runner's Avatar
My TPS says the same thing on my Auterra OBD reader, not to jump on the bandwagon, but yep, it's normal.
Old Nov 14, 2012 | 05:56 AM
dirka dave's Avatar
I just installed a new engine, shadbolt cams and bored over and was checking my tps with my ethos scanner and got these results.
Closed 8.4 %
Wot 76-82%
I guess that's ok.
Old Nov 14, 2012 | 07:17 AM
rworegon's Avatar
For reference, my 1995 Tacoma hardcopy FSM for 5vz-fe (3.4L) says:
No throttle = 7% - 11%
WOT = 65% - 75%
Voltage output of TPS calculated as a percentage of: 0V = 0%, 5V = 100%
Old Nov 16, 2012 | 04:25 AM
dirka dave's Avatar
I have another throttle body that ill test...
My engine runs fine, only has 37k (Not 37 000 lol)
Just about to change the oil.....
Old Nov 16, 2012 | 08:17 PM
BigBluePile's Avatar
Six years later......
Old Nov 17, 2012 | 09:02 AM
dirka dave's Avatar
Amazing how long stuff stays on the internet.....
some drunk guy
Aug 3, 2021 06:09 PM
LCE_Performance
Oct 1, 2015 01:03 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
larrys93pickup
Sep 17, 2015 07:05 PM
moparbay
Sep 3, 2015 12:48 PM
