3.4 sparkplug havok
Old Aug 3, 2007 | 05:00 PM
boraxman's Avatar
3.4 sparkplug havok
So I have come to realize when my Taco starts missfiring its time to replace a plug. I have tracked down this occurance 4 times in 2 years, 2x in #3 and 2x in #6 cylinders.
Whats happening is my plugs are cracking on the porcelian where the electrode comes out. Very hard to see but there and the problem none the less. I only use NGK or Denso dual electrodes.
My engine generally runs perfect and has 162K, its a '96 and has had the head gasket recall done and always serviced. All coil packs, wires etc. replaced.
So anyone else have this problem or know of a cure? Maybe im running lean?
Old Aug 5, 2007 | 11:50 AM
icerunner's Avatar
I give you props, you're are a smart dude (smarter than most) to know that misfiring is mostly with the Spark plugs.
A lot of guy don't realize that the plugs are 30,ooo Mile plugs max..... Yet, it sounds like you have a different issue all together.
Thinking out loud, if too lean a fuel mixture:
1)dirty injectors?
2)dirty fuel filter?
3) Dirty M.A.F Sensor?
...maybe...?
My question: What brand of gas are you running?
Old Aug 5, 2007 | 11:55 AM
boraxman's Avatar
Ha, didnt think I would get a reply. Hopefully it may help one person.
I use regular gas from various stations.
MAF has been kept clean but aging none the less.
Injectors never serviced.
Fuel filter about 50k ago.
Old Aug 5, 2007 | 02:01 PM
icerunner's Avatar
I can honestly say I have no Idea but i suspect it may be the injectors in the suspect cylinders spraying too lean... or semi clogged? You may want to try a "top tier" fuel such as BP or shell and go with the BP ULtimate or Shell Ultimate as i think they add much more cleaners than the standard grades and that may help with the injectors..
Please let us know what you find out
Old Aug 9, 2007 | 05:10 AM
icerunner's Avatar
Hey,
any news on the issue?
Old Aug 9, 2007 | 07:02 AM
tntempest's Avatar
You left out the pre-cat oxygen sensors, that play a vital role at determining rich and lean. To clean the injectors you could use seafoam, in tank, and to clean valves put some in the intake.
Old Aug 9, 2007 | 07:48 AM
hross14's Avatar
------While the engine is running
Read the other plugs to see whether they are running rich. If they are sooty and have lots of carbon on them--Then the clogged injector theory could be correct. i.e. O2 sensor richens the mix to account for the lean condition in the clogged cylinders. Hence the unclogged injectors would dump more fuel until the mix is correct--The down fall of only having one O2 sensor.
Steven.m.paulk
Jun 7, 2020 10:45 AM
shooter86314
Jan 7, 2016 07:05 AM
primordialbeast117
Dec 19, 2015 12:23 PM
White Stripe
Oct 6, 2015 10:47 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
