3.4 Liter Problems
Old Dec 22, 2009 | 07:08 AM
Ocean Racer's Avatar
Originally Posted by mt_goat
That's too bad, the factory cats are about $800-$900 new. To get rid of the code P0420 this usually works: http://www.urdusa.com/index.php?cPath=66_170
Yeah most people start with plugs for a misfire code. The dual ground make them last longer, since the 5VZFE uses a waste-spark ignition system. More on that: https://www.yotatech.com/forums/f2/e...h-bank-177019/
Just ordered the o2 sensor box.. hope it works..
in the past I have been able to reflash the ECU to turn the light off, is this possible?
Old Dec 22, 2009 | 08:41 AM
TheDurk's Avatar
I don't know about reflash--probably not the precise word you want--but you can reset by taking off the positive cable for 20-30 minutes. The P0420 takes a while to come back as a few trips are needed to detect and certain sequential driving sequences are required. Figure a tank of gas to complete the test. Until then a scan will show 'Test not complete'. I don't know what happens when you first install a simulator, probably the same thing.
You probably need two tanks of gas to declare victory on a P0420, I think it's the slowest code to trigger after reset.
Old Dec 22, 2009 | 10:44 AM
I am actually thinking of buying a computer to inface with the ECU via OBD2 port. It was very handy to have, borrowed one from a friend. Told me the same thing the dealer told me, any recomendations?
I do have plans to SC this motor sometime and add some HP, I read that this somtimes will require mapping of the fuel curves. So a computer that can do this is the one I want. If this is like the ones I have used on my BIG Diesel trucks and my Mitsibishi Evolution, you can also turn off the O2 sensor code warnings... that is what I was calling a Reflash...maybe your right, not the best word for it... Anyone got a better word?
Old Dec 22, 2009 | 11:32 AM
hross14's Avatar
UDR sales the computer and stuffs you need to get the job done right. One of thier systems will handle pretty much everything you need to do
the1998sr5
15
Jul 14, 2020 08:35 PM
coleypull15
Nov 3, 2015 07:41 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
94whiterunner
Jul 12, 2015 07:15 PM
Cplmike
Jul 8, 2015 08:47 PM
