3.4 fuel pump issues???
3.4(5VZ-E) Cylinder Compression:
-Standard
(218 PSI)
-Minimum
(145 PSI)
(Reading the above compression seems "normal" and with-in specification.)
3.4(5VZ-E) Fuel Pressure:
Ignition On, engine not running - (38 to 46 PSI)
Engine Idling *Vacuum hose attached* - (31 to 37 PSI)
Engine Idling *Vacuum hose detached* - (38- 44 PSI)
Fuel system hold pressure - (21 PSI)
-Standard
(218 PSI)
-Minimum
(145 PSI)
If it was starting to fail, yes, you could see issues when running. The only way to be sure would be to monitor fuel pressure under those conditions, such as wot like you say. At work we tap into the fuel system with a t and then watch how it fluctuates on a test drive.
Dang I reckon lol I'd say its done its duty huh I really don't know how to check it without the proper tools . Is there any other signs that this could be what's happening or should I just get a new one ? no hard feelings , by the way and thanks for the input I love learning
