3.0L tensioner
Old Feb 5, 2005 | 08:12 PM
hockeytown9's Avatar
3.0L tensioner
My crate install hit a bit of a snag. All my help flaked on me . Anyways I am doing the rest myself, but I cannot figure out where the tensioner goes on the 3.0L I am putting in. I didn't see them take it off, so I have no clue where it fits. Any help you guys could offer?
Old Feb 5, 2005 | 08:27 PM
dwh91102's Avatar
if your standing in front of the truck it go's more under the passenger cam wheel, just above the water pump
Old Feb 5, 2005 | 08:31 PM
Big blue truck's Avatar
Hydrolic tensioner
Hydrolic it bolts up between the a/c compressor and engine block with 2 12mm bolts.Easy from under vehicle
Old Feb 5, 2005 | 08:56 PM
DarylD's Avatar
It depends on what year you're working on . If its a 92-95 , the tensioner mounts in the fan pulley bracket and the tensioner pulley mounts to the P.S. cyl. head . If its an earlier model than the tensioner pulley pivots off a pin on the water pump and is spring loaded . If you have the later style tensioner system and they gave you an early style motor , than you have a problem as the earlier heads are not drilled to accept the newer tensioner . Hope that makes sense . Daryl
kawazx636
Oct 6, 2021 03:03 PM
smilen724
13
Nov 8, 2015 04:11 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Obmi
Sep 16, 2015 02:13 PM
moparbay
Sep 3, 2015 12:48 PM
