3.0L Engine "Drag"
Old May 13, 2005 | 11:44 AM
amigowa's Avatar
3.0L Engine "Drag"
I have a 3.0L in my 4Runner that has started dragging a bit on acceleration. And has low torque/power..
I was getting a code for the igniter which I resolved after replacing everything on the ignition side - igniter, coil, cap/rotor, plugs & wires. The drag effect is still there after changing out the ignition components. however I cured the complaint from the computer (engine light would come on at 65 or so MPH) with the resulting code for igniter problems. I've just had to do a timing belt/water pump job due to a the idler pully bearing going @ 161,000. While the timing belt/etc made the engine quiet, it didn't do anything for the drag.
I was thinking a vacuum leak, but have replaced the valve cover gaskets, PCV, etc. about a year ago.
Any chance this could be related to the EGR valve? Its a component that could cause some issues if it didn't close fully..
AmigoAZ -> now WA...
Old May 13, 2005 | 11:56 AM
hafftrak's Avatar
Have you replaced the fuel filter yet?
Old May 13, 2005 | 11:59 AM
callmej75's Avatar
i advanced my timing 2 degrees and always use fuel injector cleaner and octane booster. downside for the timing is low end loss of power but it gains higher end power.
Old May 13, 2005 | 12:09 PM
green91runner's Avatar
the yota technician said 'it will give you a lil more power on the low end' as he advanced my timing to 12-13.. although, this picked my truck right up, made it sound healthy again.
Old May 13, 2005 | 12:11 PM
callmej75's Avatar
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
Coreyr384
Jul 10, 2015 11:13 AM
