3.0 engine replacement Q
Old Mar 7, 2004 | 04:31 PM
My99's Avatar
I have a friend with a 91 pickup with the 3.0. A few years back he had the recall done by Toyota and they put in a new engine. LAst week the engine had a major malfunction in the block and so it's toast. He's getting another one put in at a local garage that supposedly has about 90K miles (of course). So my question is what do you all do to keep the headgaskets from blowing on these. I know on my car I put some ARP head studs and a better headgasket on it to keep it from blowing (turbo application). But I'm not sure what the trick is on the 3.0's. Any other suggestions I could let him know about?
Thanks
Old Mar 7, 2004 | 05:21 PM
MTL_4runner's Avatar
Thanks
Same deal there too.....definately use the head studs and torque them to a higher spec.
I believe the ARPs ask for 100 ft-lbs but don't quote me on that.
Old Mar 7, 2004 | 06:16 PM
My99's Avatar
Okay, I couldn't find the head studs for that engine.
http://store.summitracing.com/defaul...&d=1&x=11&y=12
There's the page i pulled up, but couldn't find headstuds for the 3.0 in the truck's. Also, what headgasket should one use to avoid future "problems?"
Thanks.
Old Mar 7, 2004 | 06:29 PM
amusement's Avatar
3.0 V6 Head Studs
http://www.doaracingengines.com/
Old Mar 7, 2004 | 06:30 PM
Thanks.
Here are the headstuds for the 3.0L and are worth it to prevent the blown gasket problem from happening again.
Old Mar 7, 2004 | 06:36 PM
My99's Avatar
Yes, they're worth it. Too bad they're 2X as pricey as ARP's.
Thanks fellas. SO I assume you just stick with factory replacement headgasket?
Old Mar 7, 2004 | 06:44 PM
amusement's Avatar
HKS Metal head gaskets ...
Old Mar 7, 2004 | 07:01 PM
Los Gatos?'s Avatar
MHG require a machined mirror finish on both the block and head to properly seal. That's a bit of work & expense on top of the MHG. Try to find a multi-layer gasket that isn't metal if you can!
Alaskan91
Sep 21, 2015 04:39 AM
OffroadRalph
Jul 2, 2015 07:28 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
nyk08trx
Jun 18, 2015 09:01 PM
yamaha73
Jun 18, 2015 06:19 PM
