2nd Gen OME Lifts
Old Feb 18, 2004 | 05:47 PM
Fink's Avatar
2nd Gen OME Lifts
OK..
I was just talking to Brian (waskillywabbit) about the different lift possibilites there are for my '95 Runner. He went with the 3" OME lift for his 3rd gen and didn't pay nearly as much as I was looking to pay for a lift on my 2nd genner.
My question is, does OME make a lift for the 2nd gens...if so, where can I get it and how much should I expect to pay. If not, what is a comperable lift. I was looking at spending ~$600 for the lift not including install of course.
If you guys could gimme a link to a place that would have something like this I would really appreciate it!! Thanks guys!
BTW - Yeah I searched, but...obviously didn't come up with anything.
Fink
Old Feb 18, 2004 | 06:36 PM
Fink's Avatar
*bump*
Old Feb 18, 2004 | 06:44 PM
doink's Avatar
im pretty sure they make rear coils, and shocks that fit our rigs..but i dont know anything about the front suspension. for cheap, i say you cure your rear sag, pop a 1 or 2 inch body lift, and call it a day
Old Feb 18, 2004 | 08:03 PM
Cebby's Avatar
listen to doink.
Old Feb 18, 2004 | 08:51 PM
KevyWevy's Avatar
or since im pretty sure he has already cured his sag, why not just go with the downey spacers in the back and crank the torsion bars on front? with springs, shocks and spacers, i think the price came out to about $500 from what i remember. this is what im going to do (hopefully this summer) whent he money rolls in.
oh and if im not mistaking, i think corey has some type of torsion bars that you then use coil overs on? i could just be full of it, but if i remember correctly, he has some form of coil overs on his rig. go check out his website.
Old Feb 18, 2004 | 09:09 PM
Flygtenstein's Avatar
OME makes coils and shocks with some leaf springs here and there.
$100 for ball joint spacers
$20 for used Cruiser coils
$40 for panhard drop bracket
$100 for 4Crawler Bodylift
$35 or so for low profile bumpstops
$70 for Rancho 5009 rear shocks
$70 for front air shocks
Maybe $100 for a retube on the rear shaft
The balance can be used to fly me out to install the stuff.
Seriously, that will get you on 33's, throw in a locker or two and you will smoke pretty much all the trails you can run with a body. Obviously protection of the normal sort too, but you get the idea.
Old Feb 18, 2004 | 09:56 PM
WSU4runner's Avatar
With the cruiser coils are both the rear coils the same length? or is one the short side and the other the long side coil?
I'm just curious cuz I'm looking for some and I found some used from a guy and I'm not sure if I would just need one and try to find the other somewhere else
Old Feb 19, 2004 | 06:45 AM
doink's Avatar
you have to get both long coils if im not mistaken.
kevywevy-
corey as do i,has SAW torsion bars. made by the same company as the coilovers, but no coilovers. just the torsionbars. unless he has done something really radical that i didnt know about..
Old Feb 19, 2004 | 11:15 AM
KevyWevy's Avatar
ok gotcha. i guess i just saw the SAW name and related it to coil overs.
Old Feb 19, 2004 | 11:41 AM
Fink's Avatar
How much lift would I ultimately gain from all this stuff? I was lookin for maybe like 3" if possible. I just want to gain some pretty good height and be able to tackle some pretty rough stuff...nothin serious or huge. The biggest tire I would want to run would be 35's and probably won't even end up going that big...
Thanks for the advice guys, the more the better!!
Fink
Old Feb 19, 2004 | 11:42 AM
You want rear coils.
I bought one pair that consisted of two coils, one of which was taller. It made the truck lean, so I bought another set. The next set also had one taller than the other. The taller was not as tall as the tallest, but the shorter was approximately as short as the other short one.
I then put the two tallest coils on the truck and started smiling. It sits level, rides great and I have already posted a lot of pics of it flexing. The thing is I have a heavy rear bumper, heavy rear cargo boxes and a heavy rear speaker box. This means those of you with an otherwise stock rear will be way up in the air.
Because of this, I suggest getting two of the shorter rear coils. Because the two pairs that I got each had different heights, I assume all of them do. I can only offer opinions on how things have been for me.
This set up may not make you big and bad, but it will give you enough lift and flex to wheel on 33's, maybe larger. You will be low and wide.
Do not waste your money on Sway Away torsion bars unless you have a front bumper, winch and fat girl friend to ride up there.
Old Feb 19, 2004 | 12:26 PM
doink's Avatar
yep, cancel the saw torsionbars without a winch/bumper/fatgirl friend as flygt so nicely put it
Old Feb 19, 2004 | 04:50 PM
Fink's Avatar
$125 for downey spacers
Here's the list that Flygtenstein and I came up with, well he pretty much made the list...
Anything else you guys can think of? Do you guys think I should use something else in place of the stuff listed?
Thanks for the help guys,
Fink
Old Feb 19, 2004 | 05:21 PM
WSU4runner's Avatar
Just curious but what is the retube for the rear shaft?
I'm basically going with this lift so I'm curious on what I need and I haven't see anything on this before.
Thanks
Old Feb 19, 2004 | 05:48 PM
Fink's Avatar
The shocks that Flygtenstein listed are pretty da*n long so the gas tank wil likely have some issues with the shaft, if you get it retubed smaller the interference won't be a problem anymore.
Hope that helps ya WSU.
Fink
Old Feb 23, 2004 | 06:56 AM
this would be all that I would need to clear about three inches? I mean do these pricdes include everything needed? Also, where from? I have been really close to getting some heavier torsion bars and spacers for my downeys, so I am new to this method.. Thanx
jake
Old Feb 23, 2004 | 08:45 AM
WSU4runner's Avatar
I can help you out with the Downey Spacers if you need some. I have a brand new set of them sitting around. PM me if you are interested Fink.
Jun 1, 2021 01:51 PM
nvdesertrunner
May 11, 2020 08:18 PM
vanion2
Jul 29, 2015 06:17 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Steezy96yota
Jul 6, 2015 10:00 AM
