2nd Gen Headlights
Old Sep 4, 2002 | 12:26 PM
Skydigger's Avatar
2nd Gen Headlights
One of my headlights just burnt out so I'm going to get some replacements.
Anyone know a good 'upgrade' to the stock headlamps? I could just get some more Sylvania's but is there anything better which would just plug 'n play?
Thanks,
Warren
Old Sep 4, 2002 | 12:35 PM
Toyota Punk's Avatar
From time to time I see headlights on eBay for 1st gens that allow you to use H4 bulbs instead of the standard sealed beam. They are much more clear than stock and look pretty nice. Looks like you have a 90 or 91, not sure if you have sealed beam or not. If so, they would probably work for you. If not, ignore me.
Old Sep 4, 2002 | 12:45 PM
Corey's Avatar
Co-Founder/Administrator
I ran Hella housings on my '90 truck I had, and now the 4Runner.
They are brighter than the stockers. You can also take out the 55/60 watt H4 halogen bulb in them and run a brighter one such as a 55/100.
That's what I ran in the truck.
You will notice a much better beam pattern with these since the lens is focused.
Also when the lamp burns out, just change the bulb and not the housing.
I fell into the Piaa Super White crap and bought their Super White Platinum bulbs a few years back.
They appear brighter, but are worthless in my option.
See my write-up:
http://www.pnw4runners.net/tando/piaa.htm
Although folk's with 3rd gens report nothing but nice things about the Piaa's.
They don't work well in the rain, the light all but disappears.
The stock H4 bulb that comes with the Hella housings is better IMO.
Soon I'll get around to picking up a plain pair of H4s in the 55/100 watt type.
You can get the Hella housings at Central 4WD:
http://www.central4wd.com/store/itemdetail.asp?ID=5025
These are DOT approved as they have the nubs on the lens for aiming machines.
The ones I had on my truck and now on the Runner are called the Eurobeams. Same thing as the Vision Plus lens, but mine are not DOT approved as they don't have the nubs on the lens.
Mine came out before the Vision Plus ones.
These are worth the money, just don't fall for the Piaa, or other super bulb crap.
Here is a good guy to read up on lighting. He's considered the guru of lights.
http://lighting.mbz.org/
Old Sep 4, 2002 | 03:32 PM
Krash's Avatar
/me adds another mod to the list
Old Sep 4, 2002 | 04:52 PM
Skydigger's Avatar
lights
Great ideas.
Thanks guys,
Warren
Old Sep 4, 2002 | 07:02 PM
williemon's Avatar
I use the Hella Vision plus. Bought them from Summit. They have a VERY distinct top beam cutoff. Good for not blinding other drivers.
Old Sep 4, 2002 | 11:28 PM
apc's Avatar
apc
Check out this mod I did last week. I bought some ultra small h4 halogen lamps and installed them into the headlight bezel. With it integrated behind the clear plastic protectors, they look awesome.
I also sprayed the headlights with a tint film to give it the dual round look.
http://community.webshots.com/script...ecurity=LqrwUu
suppra87
Jul 15, 2021 05:15 PM
clok
Nov 19, 2015 01:09 PM
runnermedic
13
Sep 21, 2015 05:20 PM
reallynotamechanic
Sep 11, 2015 11:52 AM
