2nd Gen. console cupholder
Old Nov 29, 2004 | 06:17 AM
TRunner's Avatar
Has anyone switched out the almost useless tray and coin slots for two or three cup holders? There is plenty of space. The only thing that will get in the way is the rear window control which could be easily put somewhere else. I was actually thinking of putting the window defroster button on the left side of the stearing wheel in one of the unused button locations and put the rearwindow switch in its place. I searched this group and found only 3rd generation folks doing it and running into problems with there "sadan" style E-brake.
Old Nov 29, 2004 | 11:58 AM
TRunner's Avatar
bumpitybumpbump...
Anyone in here do any fiberglass work?
Old Nov 29, 2004 | 04:07 PM
Cebby's Avatar
I have something in the works. I got cupholder inserts in black that I plan to fit with a little fiberglass work.
Here's the link to the cup holders: http://store.tackletogo.com/thmarflusmou.html
Old Nov 30, 2004 | 04:18 AM
TRunner's Avatar
I would really like the ones out of a 2000 Dodge Durango. They work very well. So, if I find one in a junk yard, I should be able to cut it down to size and add fiberglass to shape it, right? Then with a coat of bondo and paint, it should look real good, huh?
Old Dec 1, 2004 | 11:35 AM
TRunner's Avatar
<Bump>
Anyone in here use fiberglass before?
Old Dec 1, 2004 | 02:39 PM
Cebby's Avatar
I searched the car audio sites for info on fiberglassing. It has been prevalent there for a long time. I used to work with it alot back in the day, but not much in the last 6 years or so.
Do you have a specific question?
Old Dec 2, 2004 | 05:34 AM
TRunner's Avatar
Could I use a cutaway of an existing console from another vehicle and add fiberglass to it in order to make it fit my truck? In other words, does it bond easily to the plastics used in consoles?
Old Dec 2, 2004 | 07:17 AM
Cebby's Avatar
If you rough up the plastic by sanding it will stick nicely. I have done door panels, dash pieces, consoles, sub boxes, etc. You might have to reinforce the plastic to make it more rigid depending on what console you are grafting in. If the subtrate flexes, it "could" pull away from the fiberglass material. Mechanically fasten, glue or "kitty hair them together before using fiberglass matte.
Old Dec 2, 2004 | 07:45 AM
TRunner's Avatar
(flipping through dictonary...)
What's subtrate and kitty hair? Other then that I am all for giving it a try. The only fiberglass work I have done is on body repair of an old spitfire. That and a coat of bondo worked great and was very easy to work with.
Old Dec 2, 2004 | 09:22 AM
914runner's Avatar
Hey Cebby, What are some good car audio forums and sites to go to? I wantto make a custom console but first I would like to read up on fiberglassing.
Thanks
Old Dec 2, 2004 | 10:56 AM
Cebby's Avatar
Substrate = Console (or whatever you are glassing over)
Kittyhair = bondo with glass strands in it like USC - Duraglas.
Old Dec 2, 2004 | 10:58 AM
Cebby's Avatar
Thanks
Let me dig through my old bookmarks and see what I can come up with.
Old Dec 2, 2004 | 12:42 PM
TRunner's Avatar
Gotcha! Thanks a bunch!
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
reallynotamechanic
Sep 11, 2015 11:52 AM
icentropy
Sep 10, 2015 05:03 AM
Highlander Giant
Sep 8, 2015 06:46 PM
