2nd gen better master cylinder swap?
Old Dec 1, 2004 | 10:54 PM
Joyota's Avatar
Question 2nd gen better master cylinder swap?
After looking at my brake master cylinder, the best I can tell, it has only one complete reservoir, with no separator. In other words, if your front brakes fail, so do the rears. Is there a swap available that addresses this problem? As always, money is an issue, so I would prefer a swap from a vehicle that I could find at my local pick-n-pull.
Old Dec 2, 2004 | 09:52 AM
914runner's Avatar
About the only (all ) upgrade for MS that I know of is the FJ-80 non-ABS MS swap, but I am not sure if it does what you want?
Old Dec 2, 2004 | 11:00 AM
4x4Lamm's Avatar
The systems are indipendent, but only one master. If it breaks, you can still stop once or twice. Then, call a tow truck. Don't be a hero and "limp" home only to rear end someone at a stoplight.
Lamm
Old Dec 2, 2004 | 11:57 AM
Nathan Buchanan's Avatar
They have some sort of seperator; I drove around for a couple of days without any rear brakes when one of my line busted.
Old Dec 2, 2004 | 01:21 PM
914runner's Avatar
Wouldnt DOT have a law that makes that mandatory?
Old Dec 2, 2004 | 01:22 PM
4x4Lamm's Avatar
I belive you are correct.
Lamm
Old Dec 2, 2004 | 01:26 PM
Joyota's Avatar
Post
I'm pretty sure you're right about the FJ80 MC. I think it will only work if you swap the rear drums for discs.
Lamm and Nathan, you are both right. In my ignorance, I never thought to look inside the reservoir. From the outside, it looks like all one tank. Today I stuck my finger in there and there is a separator that is about half the height of the reservoir. More details when I get home from work.
Old Dec 2, 2004 | 06:23 PM
Joyota's Avatar
Post
Ok, now that I'm home from work, "and changed my rear differential oil" , I'll say what I was gonna say earlier. This all came about because of an incident that happened about 4 months ago (I bought the truck in May). I go to the bank to deposit the paycheck. I pull out and go about a half a block to the intersection. I hit the brakes... nothing. I drop 'er into 1st, dump the clutch and turn off the ignition. She stops about a foot from the crosswalk, where pedestrians were crossing and it was also a main road, so lots of traffic. I came about a foot from hitting a girl and her boyfriend who were crossing the road. Let me tell you now... That was the worst experience of my 23 years of driving.. :pat:
So, I want to take every precaution that I possibly can to prevent this from happening again... Thus the Master Cylinder question.
After this happened, and I replaced the driver's side brake lines and hose, I also replaced my rear shoes, only to find that they were not adjusted at all. In fact, the self-adjusters aren't even there! So, I replaced the shoes, adjusted them by hand and am currently looking for new (or used) self-adjusters. I also plan on stainless lines, front to rear this spring.
By the way, when I replaced the shoes, my pedal came all the way up. So, I guess what happened is... The front brake line failed... The rear brake shoes weren't adjusted, and that's why they didn't kick in... Not because of the master cylinder
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
tobylab
Jul 12, 2015 12:53 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
