2nd Gen--120k Mi Service
Old Sep 5, 2003 | 12:53 PM
Nodlew505's Avatar
I am going to pass on the $600 proctological exam from the stealership and do the 120k mile service myself. I am going pretty much OEM--coolant, distributor cap, plugs, wires, rotors, timing belt, etc; but wanted to get input from you 2nd Gen gurus on fluid choice for diffs, tranny and transfer case...any preferences with regard to manufactures, products, etc.
Cheers
Thanks,
Weldon
Old Sep 6, 2003 | 09:19 AM
CTB's Avatar
CTB
Hey there,
As far as fluids go in my diffs and transfer case, I use either Coastal or Valvoline (which ever they have stocked up at Auto Zone at the time) gear oil in my diffs and transfer case. I use 75w-90 in both my diffs and transfer case.
Check to be sure, but if you have an auto tranny, you may take ATF fluid in your transfer case (I can't remeber for sure).
I don't mind use non-synthetic since I change my fluids every 20K miles or so.
Old Sep 6, 2003 | 06:27 PM
EDGE's Avatar
600 bucks, did you ask them what that included cause 120k service should cost the same as the 30k service plus a few things
Most small shops if they still excist will probably do they services you need for little more than cost of parts
Old Sep 7, 2003 | 02:05 PM
Reldnew's Avatar
Same as CTB for me. If you have an auto you take 1.1 qts of tranny fluid in the transfer case. I used Semi-Synth last time. Many people here Love Amsoil and Mobil 1, and I don't think you could go wrong with either-oils, greases or ATF.
suppra87
Jul 15, 2021 05:15 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
charlie_fong
Sep 27, 2015 10:06 PM
runnermedic
13
Sep 21, 2015 05:20 PM
reallynotamechanic
Sep 11, 2015 11:52 AM
