285's with no regear..thoughts?
Old Feb 25, 2008 | 07:19 AM
Nate08's Avatar
Okay. I'm getting 14.5-15MPG if I milk it. Stock I got about 17-17.5 if I milked it. Maybe its worth looking into.
Old Feb 25, 2008 | 07:39 AM
Taro's Avatar
If you have an auto get 4.88's and not 4.56's. The difference will be around 150rpm on the freeway between the 2. If anything, I think that would help mpg and not hurt it.
Old Feb 25, 2008 | 07:57 AM
toy_tek's Avatar
Personally I wouldn't consider regearing strictly for MPG purposes. If you figure $1000 for regearing (including labor and misc parts) that would buy a lot of gas if you're looking for a 2 MPG increase.
But the performance benefits to regearing justified the cost for me.
Old Feb 25, 2008 | 08:57 AM
Taro's Avatar
True, the performance makes it worth it. But 2mpg on a road trip to Alaska makes a big difference. Not just the money but the range. That's about a 15% difference going from 14 to 16 mpg. It adds up.
I bought my 4runner because I wouldn't be happy with 14mpg. That's kinda sad. Might as well buy an FJ80 or a fullsize if that's all you get.
Old Feb 25, 2008 | 09:36 AM
  #25
Mason Dixon's Avatar
Does it take specialized tools like a press to regear? Has anyone DIY'ed it?
Old Feb 25, 2008 | 04:51 PM
  #26
Bighead's Avatar
Look at Zuk's site to what it involves.
Old Feb 25, 2008 | 05:57 PM
  #27
d0ubledown's Avatar
X2. anyone can DIY it...whether or not it'll blow up 100 miles down the road is a different story...
i didnt regear when i went to 285's. i was on 4.30's though. then i went 315's. there was a bigger difference going stock to 285's than going 285's to 315's...it just sucked more. then i went to 4.88's. much better. labour is about 3.5 hrs per end..thats if you pull the third out and bring it in. add a few more hours if they do it for you. you can get full regear kits for about 6 or so bills...master install kits included.
stay with alloys if youre not planning on regearing...steelies will also be heavier and thus slower...and every little bit helps.
Old Feb 25, 2008 | 06:00 PM
  #28
Taro's Avatar
Originally Posted by d0ubledown
it just sucked more
quote of the day there
Old Feb 25, 2008 | 09:32 PM
  #29
Psalm 112's Avatar
By "Fine" I mean, Good, Super, Almost Pre-285s. Getting on and off the freeway is not a problem. I'm not passing folks left and right, but it runs Fine...
Someone mentioned the Speedometer being affected...that is true...
Old Feb 26, 2008 | 10:35 AM
  #30
Donovan's Avatar
I got 285s last year. My 4Runner is a 2002 with a supercharger and TRD cat back. I did notice a little lag when I first got the tires put on but now it fels normal to me. I use OD lockout on hills and mountain driving and I use the ECT Power button around town and in the mountains. MPG went down a little but he spedo is off so I don't know how much exactly. I air up a bit more when I'm street driving only.
The main problem I have is keeping the damn things ballanced!! The shaking is driving me nuts!
Old Feb 26, 2008 | 11:39 AM
  #31
Nate08's Avatar
It might be the tires. I got my Nitto's (285's) and they balanced out perfectly...0.00's across the board. They are really smooth on the interstate without any shake or wobble.
What kind of tires are you running?
Old Feb 26, 2008 | 12:04 PM
  #32
pfdaxe's Avatar
You may have warped rotors. That's been an issue before.
Old Feb 26, 2008 | 04:11 PM
  #33
Donovan's Avatar
I got the same tires as you do
dragr1
12
Jun 27, 2004 09:55 AM
Gringo
Feb 25, 2004 03:31 PM
4runner4life2
Jan 7, 2004 11:20 AM
RTdawgs
7
Jun 10, 2002 06:29 AM
