22RE specs help
Old Apr 15, 2004 | 09:16 PM
nigeltufnel3's Avatar
Arrow 22RE specs help
well, somehow i don't have the underhood sticker that has the specs for my engine, so maybe someone could help me out. I have a 1994 Pickup, 22RE, 4x4. What are the specs for the ignition timing? One more thing, is it really important to reset the whole timing curve, or will just the base be fine? Thanks for all the help.
(Sorry, I posted this over at 4x4wire, I don't mean to be lame and post it everywhere, but i need to know by tommorow morning. thanks.)
Old Apr 16, 2004 | 04:19 AM
Yoda's Avatar
Engine should be warm, all accessories off
base timing is 5 deg btdc @ 750 RPM with the jumper installed on the data link connector (jumper wire between the TE1 terminal and the E1 terminal)
"Advance" setting is 10-14 deg without the jumper @750 RPM.
Base timing is the only thing you set. The advance is just a check. The computer controls all the timing after the base is set and the jumper is removed.
Blamalam
Mar 12, 2022 07:34 AM
Dennisx2
Aug 10, 2015 06:48 AM
rustym
Aug 7, 2015 10:39 AM
Dennisx2
Aug 4, 2015 01:26 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
