22re part identification
Old Dec 30, 2004 | 09:05 AM
Coldforged's Avatar
Got a quick question for you guys. I'm building my 88 4runners 22re back up after a rebuild and for the life of me I can't remember where this part goes. I think it's a pulley brace but I'm not sure. Could anyone provide a detailed description of where it goes? Here's a picture:
Old Dec 30, 2004 | 10:09 AM
Joyota's Avatar
I left out the same bracket after my head gasket replacement. It mounts to the bottom of the power steering pump (arrow).
Old Dec 30, 2004 | 10:31 AM
Joyota's Avatar
Also, the hole on the top-left of your picture is the one next to the arrow in mine. One of the holes mounts to the front of the timing cover.
Old Dec 30, 2004 | 10:47 AM
motrhedx81's Avatar
Alternator bracket. Like Jovis said, the threaded hole goes on the back of the PS pump bracket and the other side goes on the front of the timing cover. The radiused hole in the bracked should match up with the curve of the way the alternator swings back and forth. Set your alternator loose in its bottom mounting hole, that way you can get a better idea of where the bracket fits in.
I had the same problem when I put all mine back together. I had to take all the PS brackets off to get that thing back up into place, because it fits just right up in there to where I couldn't wiggle it back in.
Old Dec 30, 2004 | 10:51 AM
86toyota's Avatar
Found this pic from when I was doing my timing chain. Hope this helps.
Old Dec 30, 2004 | 01:34 PM
Coldforged's Avatar
Thanks for the help guys. I'm not sure I would have ever spotted where it went.
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Nickdigg
Jul 7, 2015 06:04 AM
bryan34w
Jul 6, 2015 05:53 PM
