22re Flywheel resurface - Step height?
Old Jan 3, 2005 | 04:39 PM
CrazyDiamond's Avatar
Just trying to find what the stock flywheel step height for a 22re is, and what non-stock steps people here have used when they got their flywheels resurfaced...
I think stock is around .020", but I've heard alot of people using a step of .026".
Incidentally, I'm installing a new Centerforce Dual Friction clutch with a stock weight flywheel.
All opinions welcomed!
Old Jan 4, 2005 | 07:04 AM
Hmmm...anyone have any input? Where are my yotatech homies??
Old Jan 15, 2005 | 09:29 PM
Just throwin this back up to see if anyone has any input. Input appreciated, as always!
Old Jan 15, 2005 | 09:47 PM
superjoe83's Avatar
i thought the 22r/re flywheels were completely flat, well if there is a step then i would think that less is better, the more you have puts the pressure plate farther away from the disc, and you will have less holding pressure as the clutch wears
Old Jan 16, 2005 | 08:24 AM
86toyota's Avatar
Wouldn't the more step you have make everything tighter. I have the CF Dual friction plus 10LB heavier flywheel. It's going on 8yrs turning 33's. Any machine shop should know what the step height should be.
Old Jan 16, 2005 | 12:54 PM
Yeah....more step = tighter. It brings the pressure plate closer to the clutch disc. Thanks guys.
4x4-runner
Dec 27, 2016 01:58 PM
Sep 4, 2015 09:27 AM
TransAmBandit
Jul 28, 2015 11:30 PM
Nickdigg
Jul 7, 2015 06:04 AM
