22re conversion from 3.0
Old Jun 30, 2003 | 05:24 PM
I know this is kind of goes against the grain here, but has anyone converted a 3.0 slow to an even slower 22re in a 4runner? If so, can you tell me how it went and what you did?
I happen to feel that the 22re is a much more reliable motor than the 3.0
Jason
Old Jun 30, 2003 | 05:28 PM
Cebby's Avatar
Your profile says 96 4Runner. That would have a 3.4 V6 which is a good motor.
If it's actually a 2nd Gen, it can be done, but why not consider the Supra motor swap.
Old Jun 30, 2003 | 05:47 PM
Ok, here's the deal. I have a 96, good running vehicle. I have access to an 88 for a winter beater with blown head gaskets, I can get it for 500, everything else works, so i also have access to a 22re fairly cheap and was thinking on swapping it out. But, if the supra motor is cheap and easy I would consider it.
Old Jun 30, 2003 | 06:41 PM
1Runner's Avatar
If it's in an 88, I'd go w/ the 22re. I agree w/ you 100%. Those things are bullit proof.
Old Jun 30, 2003 | 06:44 PM
1Runner's Avatar
Sorry, BULLET proof. No sleep yet...... my son says "It will be a while yet daddy...... I'm gonna fill my diaper again."
(3.5 mos. the kid is a poopin' machine!!! I'm SO proud.)
Old Jan 8, 2007 | 04:27 PM
yogib's Avatar
3.slow to 22re conversion
I have done this on my 93 4runner.Had to use different drivelines than stock.Front to short rear to long.Have to use 22re truck tranny crossmember under w56 tranny.W56 is longer than R150.Only wiring issue I have run into so far is V-6 has a different plug behind computer that deals with fuel pump,gauges,and dont know what else yet.Not done.Have to cut plug off 3.0 harness from motor and find out what goes where.Motor mounts had to be cut off frame and new ones mounted approx. 2 inches further forward.AC compressor pulley doesnt line up need 22re compressor and lines.power steering has different setup as well need to modify.
tobylab
Jan 18, 2016 07:06 PM
coleypull15
Nov 3, 2015 07:41 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Gone Fission
Jul 24, 2015 12:49 PM
tobylab
Jul 12, 2015 12:53 PM
