22re cam swap HELP!!!
Old Mar 5, 2005 | 04:37 PM
spfiveorcr's Avatar
Hi, well about 2 months ago I bought a rebuilt head w/ cam and put it on my 1990 22re. Last friday the truck just started making a knocking noise and It sounded like a main to me and all of a sudden it died. When I pulled it apart I found that the cam wasnt spining because the machine shop rigged two dowel pins in the cam with a broken one deep inside and the first one wiggled out (WTF!!! only 30 day warranty so Im stuck. WEll i put a new cam in now i can seem to get the timing gear and chain back onto the new cam? What am i doing wrong, Im trying to avoid pulling the front cover.
THanks
Old Mar 5, 2005 | 04:42 PM
jimbo74's Avatar
line the timing mark on the crank pulley up to 0 and have 1 one spark plug removed... with the piston @ tdc, make sure the 0 mark o nthe cam is straight up (little pin) and put the chain on the 2.....
Old Mar 5, 2005 | 04:47 PM
superjoe83's Avatar
the tensioner popped out, its on the passenger side of the motor, try to push it back in with a screw driver or some thing similar, and if the the cam did stop with the engine running i bet you have some bent valves, that was the knock you heard
Old Mar 5, 2005 | 10:33 PM
spfiveorcr's Avatar
thanks, ill try that tommorow. I know, i hope i didnt bend any valves, I just spent money on this head two months ago!
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
coleypull15
Nov 3, 2015 07:41 AM
deepmarsh
Aug 6, 2015 03:44 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
