20r and 22 r motor
Old Nov 21, 2005 | 06:22 PM
mudslinging4x4's Avatar
20r and 22 r motor
i just blew up te 22r motor and we got a 20r motor to drop back into my truck is there anything i can swap onto the 20 r motor from the 22r ? i know the intake is diffrent but can i swap carbs ? or heads?
Old Nov 21, 2005 | 06:43 PM
kyle_22r's Avatar
what year 22R? the 20R will bolt in, but the carb and emissions wiring/hoses will be different. as for the tranny and engine mounts, it's the same as a 22R.
you can put a 20R head on an '81-84 22R and vice versa.
Old Nov 21, 2005 | 07:09 PM
Bill's Avatar
Intake is different yes. But exhaust is all the same. Depending on what blew on the 22R, you may be able to hybrid the 2 engines.
If you swap the 22R head for the 20R, you'll get an imediate increase in compression
(= more power).
Old Nov 21, 2005 | 07:12 PM
DudeBud's Avatar
(= more power).
thats if he has an early 22r
Old Nov 21, 2005 | 09:00 PM
kyle_22r's Avatar
and no, you won't get a noticeable increase in compression. the combustion chamber on the 20R head is just a tad smaller than the 22R. the main gain is throttle response and it's ability to rev higher, since the 20R uses a smaller ports that go directly to the combustion chamber, instead of around a swirl ledge like a 22R.
80Truck
Oct 12, 2025 07:25 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Flossy
Aug 5, 2015 05:14 PM
calderp
Jul 27, 2015 09:58 AM
