2003 Taco Intake Silencer Mod Success
Glad to hear all is finalized and together. At the very least, you spent a very small amount of money, got some grunt and atleast 5+ hp. And also a cleaner looking engine. Nothing wrong with any of that.
Billy
Billy
Originally posted by WATRD
Not funny at all Galen, that is a common misconception amongst those who have never run a snorkel.
The design of the snorkel is such that most water is shunted out through ports in the down tube. My filter is as dry as yours, except that when a drop or two does get by on mine, it has a place to collect and "boil" off into harmless vapor.
As you said, to each his own, if you like it, fine. But it doesn't provide any proven gain except noise and it has a downside.
As for the two magical water droplets that get by my filter and stay suspended in the airstream all the way up the 2 feet or so of intake tubing, past the throttle plate and around all the bends and curves of the intake manifold then into a cylinder; well I've yet to see that happen. Gadget doesn't seem to have any problems with his intake silencerless intake(s) as well. You going to tell Gadget he screwed up? I'm sure he'll have something to say about that...
I've shown the ISR mod to a few people who design engines and high performance parts for a living and they've all had the same thoughts about it as I did when I first came upon the idea; the intake silencer on these engines is simply that, and intake silencer and not a moisture collector or performance enhancer.
It won't contribute to any torque or horsepower gains since the volume of the silencer is too small for that on this engine. If the intake runners on the intake manifold were a lot shorter, then a resevoir in front of the throttle body would probably help with cylinder filling. Seeing that the size of the plenum itself is rather large, it has the characteristics of the aformentioned resevoir.
Concerning your statement about it not being proven to provide any gains except noise; Christian (96 Runner) gave us some hard data about that. But since he didn't do 100 runs, then I'm sure you've already poo-pooed the data as not being statistically significant. Which is why I'm not going to bother spending hundreds of dollars on dyno runs proving a mod that I know works and one that I spent about $30 on. It just doesn't make sense.
As for the noise, well it's pretty loud, but I still don't see any downsides other than that after living with it for over a year. And according to you, the ISR mod was supposed to be shown to be damaging to all the engines it's been installed on by now... Where's all your hard data about how bad it is? You haven't stepped up and brought anything to the table concerning it either, Rob. You just keep saying to people who chime in who've recently done the mod, "search some other forums and you'll find what I'm talking about". I get several emails a week from people asking for advice about the mod and I yet to get one from someone that tells me it ruined their engine, but they all tell me how it enhanced their engines performance.
It's time to put up or shut up Rob. You haven't proven that it's bad for these engines, nor have you proven that it doesn't provide any performance gains.
Peace.
G
Originally posted by Dr. Zhivago
Actually Rob, it is funny since all the marketing and application data and sales videos for snorkels emphatically illustrate how they are designed to allow deep water crossings while keeping it out of your intake. Are you saying that's not what they're for? And that all those "Action" videos are misleading? If a snorkel doesn't keep water out of the intake, what possible benefit could there be to running one?
As for the two magical water droplets that get by my filter and stay suspended in the airstream all the way up the 2 feet or so of intake tubing, past the throttle plate and around all the bends and curves of the intake manifold then into a cylinder; well I've yet to see that happen. Gadget doesn't seem to have any problems with his intake silencerless intake(s) as well. You going to tell Gadget he screwed up? I'm sure he'll have something to say about that...?
It won't contribute to any torque or horsepower gains since the volume of the silencer is too small for that on this engine. If the intake runners on the intake manifold were a lot shorter, then a resevoir in front of the throttle body would probably help with cylinder filling. Seeing that the size of the plenum itself is rather large, it has the characteristics of the aformentioned resevoir..
Read more carefully. Not once have I said that the mod was damaging to all engines. But I will repeat what I have been saying just for you; "There is a potential for damage from this mod". Got it? Besides, your logic is flawed. You could drive around for a year without seatbelts without anything happening as well. But when the time comes that you need it and don't have it, WHAM!
I assume you are familiar with Google? I posted a mess of links once, since you are the chief proponent of the mod, you do some research this time.
Peace.
G
Peace.
G
#25
For what it's worth - I thought the ISR mod did give a bit of a performance edge. BUT... the amount of noise that it gave out kind of poopooed the performance it provided. That and I was a little tired of listening for possible pinging and paying the extra .10-.20 per gallon for gas.
Whoa, loudawg - did you ever think that your post would trigger this debate again
EDIT-
I forgot to mention, I was also feeling a bit wary about the *possibility* of moisture. It can get quite foggy here sometimes - especially near the ocean. I haven't done enough research (too lazy, I'm sure someone else will
) so I figure I'm better off nearly back to stock.
That doesn't mean I've thrown away the parts. I may put it back on when I know exactly what I'm listening for and I know without a doubt that there is little to no possibility for damage.
EDIT-
) so I figure I'm better off nearly back to stock.That doesn't mean I've thrown away the parts. I may put it back on when I know exactly what I'm listening for and I know without a doubt that there is little to no possibility for damage.
#26
I've ran thru waves on the beach which splashed completely over the hood and roof of my truck with the deckplate open and of course with the ISR mod in place.
G
G
i have this slow motion image of your truck driving through the surf on a Pacific Northwest beach, with seagulls flying and Enya music playing . . . .
think that would make a good Toyota commercial?
creed
#28
Huh? Actually, it was you who implied that "a snorkel which extends above your roofline" somehow increased the risk of water ingestion. I simply explained that wasn't the case.
So you monitor ALL the air going into your engine? I am not sure how you would "see" that happen. I have never said that doing the mod would result in the spontaneous destruction of your motor or anything similar. What I have said is that the traps provide an extra magin of safety. When you go through something a bit more difficult than the "puddles" you held up as an example, those traps are there as a just in case.
I see. And the placement of the "J" tube directly over the exhaust is a coincidence I assume...
My point exactly. No torque, no horsepower. So that makes it a noisemaker that *might* improve throttle response a smidgen. Hardly worth the effort and certainly not worth the risk if my absurd fantasies about it catching water are true.
I think you will find that the figures there are within the error margin of the tools used to measure the run. You are correct. One run with homeowner equipment is not statistically significant.
If I wanted a noisemaker, I would put playing cards in my spokes.
hahahahahha! That's a riot! You are the one who claims gains from the mod and who took a mod that clubs have been doing for YEARS and named it after yourself. It is not up to me to prove a negative, that the mod does nothing for performance, it is up to you to prove what you assert, that it actually does something beyond making noise and that it won't cause damage.
Right back at ya.
I'm done with this. I know that you'll never agree that this mod is a positive, even if I did 20 dyno runs to prove it, because the "margin of error" would be in effect...
G
#29
creed
creed
You can direct, Creed.
G
#30
My hope in voicing my concern is that people will not do ANY mod blindly, without putting in some research. They ALL have some sort of downside, it's a question of whether that downside is something you can live with. We have some rather non-technical folks on here and they need to know what they are going to get from a mod and what it is going to "cost" them. It doesn't matter what you or I say or what Toyota calls a part. Folks need to look into the vast wealth of automotive knowledge available and understand what they are getting themselves into.
For the record, I meant what I said in your thread about your SAS. I think it's cool that you're brave enough to take a torch to your truck...
#32
Well. I have looked at both arguments and i cant see any benefits to doing the mod other than making your rig noisy. But i was 20 once and if i could make my car noisier. Gad Damn it i was gonna make it noisier . And if you do swamp your motor in water those resonators might do a bit to help but who knows.
The way i see it is. toyota spends millions on R&D . They dont add things for no reason. But if you want to play with your truck and cut things off like i sure did when i was young. Then go for it.
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
Sep 3, 2015 09:01 PM
dropzone
Aug 11, 2015 05:16 PM
