2003 4Runner Rotten Egg Smell
Old Jun 16, 2003 | 02:54 PM
EDGE's Avatar
Originally posted by vmaxjohn
Good luck, I recommend the pine tree air freshener!
Old Jun 16, 2003 | 04:46 PM
edge its nice to make light of the situation but for us who have this problem we would like to be able to enjoy the truck jist like you and we cant obviously you are interested in knowing what is going on other wise you wouldnt make you comments but that is why this foum was made to see how many people have this problem if you dont like then stop reading and go on your way
as far as air freshners go they dont work on cigarrete odors why would they work on this
your rigth though it is typical of companies like ford which ever i am going to get my lawyer involved i bet the budge then . ill also and them back the keys and tell them where to shovel it and get something better then if there is something
Old Jun 16, 2003 | 06:12 PM
EDGE's Avatar
smelly4runner
I have the same smell, good luck with the lemon law
Old Jun 16, 2003 | 06:18 PM
The Dutch Man's Avatar
Ditto here as well. Same smell only when really romping on the gas. Tried all grades and all brands of gas. Higher grades improve things, but the smell is still there. With enough complaints from all of us, Toyota may do something. We'll see!
Old Jun 17, 2003 | 06:56 AM
  #25
Unhappy Smelly Exhaust
I've got a SC 4Runner with larger injectors. The smell is definitely caused by running rich and retarded timing. I had my o2 sensor short to ground indicating a lean condition so the computer tried to compensate to full rich and I had a full time stinker till I found the problem. I've also been playing with the mix using an FTC-1 to trim the fuel. I understand the ECU automatically retards the timing under hard acceleration based on sensor inputs (knock sensor, TPS, etc.) this allow more unburned gasses to the cat which makes it a stinker. Running higher octane gas helps some because it reduces the amount of knocking. This helps keep the timing more advanced. So unless you can program your timing, I'm afraid you have to live with it, but it does preserve the engine by keeping it from knocking as much and running cool (rich) under hard acceleration.
Old Jun 17, 2003 | 09:16 AM
  #26
Liberator's Avatar
Exclamation
I had a new Jeep a little while back, and there was that rotten egg smell for at least 10,000 km it was gutwrenching. But the plus side it did burn off before I happened to roll it at 26,000km's so have a little patience, or hopefully Toyota comes up with a solution before mine gets here.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
mskalmus
May 28, 2017 07:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
