2002 4Runner Deckplate Mod
Old Nov 17, 2002 | 12:09 PM
Dana Pereau's Avatar
After removing the elbow in front of the airbox inside the fender, I get a check engine light- I presume it is due to increased air and the computer has been thrown off and caused the check engine light to come on. How can I reset the check engine light without having to go to the dealer?
Old Nov 17, 2002 | 12:11 PM
Question
did you do the deckplate mod or elbow removal? ..
Old Nov 17, 2002 | 12:13 PM
just the elbow removal, because I have a supercharger, and Gadget says not to do the full deck plate mod with a supercharger unless doing all the other fuel mods- I am not doing the other mods, so I merely removed the elbow- should I take out the EFI fuse for a few minutes?
Old Nov 17, 2002 | 12:21 PM
I guess the title on the thread kinda threw me off..anyway, you can unplug the EFI fuse for a few minutes and see if that works. I have a s/c too with the deckplate mod and the only fuel mod I did was the Free FMU which was also inspired by Gadget's site.
Old Nov 17, 2002 | 12:38 PM
Tried remiving the EFI fuse for about 15 minutes, then disconnected the positive lead to the battery, still no luck- engine light still on. Suggestions?
Old Nov 17, 2002 | 02:04 PM
Beowulf's Avatar
Have you tried putting the elbow back in to make sure that is the cause of it?
Old Nov 17, 2002 | 03:11 PM
Jay's Avatar
Jay
Hello Dana
If after removing the "EFI" fuse and starting the engine, you have the check engine light coming on immediatly, you have left something disconnected. The first thing that comes to mind is the MAF (Mass Air Flow sensor) connector. This is located just past the air filter housing towards the engine.
Pretty much all the other likely things that would cause the check engine light to come on, would take a while of driving before the computer actually performed a test to detect the malfunction.
Jay
Old Nov 17, 2002 | 03:28 PM
Checked MAF plug- it is plugged in tight- took fuse out, replaced- ck engine light comes on as soon as I begin to turn ignition to accessory- then stays on after engine starts- engine runs great- just don't know how to reset light
Old Nov 17, 2002 | 03:35 PM
Jay's Avatar
Jay
At this moment, the check engine lights coming on is only confirming for you that the bulb works. aka "Buld Check".
then stays on after engine starts- engine runs great-just don't know how to reset light
I only suspect your not pulling the correct fuse. EFI Fuse is 30A? Blue i believe? That should definitally clear it out.
Something here seems weird....
Jay
Old Nov 17, 2002 | 03:38 PM
I'll go check the fuse again- I thought it was a black relay under the EFI square inside the fuse box under the hood- I'll check again
Old Nov 17, 2002 | 03:44 PM
Jay's Avatar
Jay
Thats the problem.... your puling the EFI Main Relay, not the EFI Fuse.
I think youll see what I mean this time.
Jay
Old Nov 17, 2002 | 03:56 PM
OK, I see that there is a 20A EFI Fuse and an EFI relay- do I take them both out? How long do I leave them out before restarting engine? Should I take them out while the engine is running? Off? Key on? Key off? Key in ignition? Out of ignition? Sorry I am such a dufus, but this is my first new car in 13 years- MY other car is a 1978 GMC pickup with a motor, tranny, and four tires, and it just goes FAST....no computer, no EFI, nothing complicated. Thanks for the help
Old Nov 17, 2002 | 03:59 PM
Jay's Avatar
Jay
Key off. Engine not running.
Leave fuse out for approx 30 secs should do the trick. No need to pull the relay.
Jay
Old Nov 17, 2002 | 04:03 PM
on my way.
Old Nov 17, 2002 | 04:15 PM
No luck- checked the MAF plug, OK. Everything is plugged in. Took out fuse. Kept out for a few minutes. Put fuse back in. Started engine, Check engine light stays on, then VSC and VSC off lights come on as well after a few seconds- ???
Old Nov 17, 2002 | 04:18 PM
Jay's Avatar
Jay
Wha??
*thinking*
Jay
Old Nov 17, 2002 | 04:22 PM
no big deal, my Toyota mechanic sid just to bring it in tomorrow morning and he'll reset it- I just thought it woud be a cake walk- the only thing different than this morning when everything was fine, is that the elbow is gone- same air filter, same everything- no elbow. ??
Old Nov 17, 2002 | 04:26 PM
Jay's Avatar
Jay
I dont see how the missing elbow could cause the check engine light to come on.
I would be very curious to know what the DTC # is, when your pal checks it.
The only thing I can think of, seeming how I always clear the codes using the Toyota Handheld scanner, is that they removed the ability to clear the codes by pulling the EFI Fuse.
Jay
Old Nov 17, 2002 | 04:33 PM
Thanks for your help Jay- I'll let you know what the code is when he clears it- I'mm outta here- wife says it's time to stop screwing around with the rig and eat!
Old Nov 17, 2002 | 04:35 PM
Jay's Avatar
Jay
mmmm.....
Best of Luck to ya.
Jay
