2001 Tacoma disable FWD?
Old Jul 16, 2006 | 11:08 AM
bf253's Avatar
Question 2001 Tacoma disable FWD?
I need to use the L4 mode of my manual transmission, but with the front wheel drive disinaged. It looks like all the control is done within the front differential case. Any way to override this function to get basically an L2 mode?
Thanks
Old Jul 16, 2006 | 11:23 AM
123c's Avatar
Your answer is right here: http://www.marlincrawler.com/htm/tra...twin_stick.htm
Old Jul 16, 2006 | 02:19 PM
youngbuck's Avatar
You'll probably like this one better:
http://tacomaterritory.com/forum/showthread.php?t=43
Old Jul 16, 2006 | 06:04 PM
Tanto's Avatar
Manual hubs.
Old Jul 16, 2006 | 08:44 PM
BruceTS's Avatar
That option won't work on manual transmission models.......
You have 3 options, 2 of them have been suggested the third is adding a dual T-case assembly from Marlin....
The twin stick requires you to take the transfer case apart, to remove the shifter rail lockout pin.....
Manual hubs require you to replace both front CV's and hub assemblies, usually you'll need to finda a donor vehicle and just buy the complete spindle assemblies, cost is around $500
Dual cases requires the most work.....but gives you much more gear options......
LCE_Performance
Oct 1, 2015 01:03 PM
bryan34w
12
Sep 30, 2015 02:50 PM
irv
Sep 29, 2015 01:04 PM
charlie_fong
Sep 27, 2015 10:06 PM
Project90
Sep 24, 2015 11:40 PM
