2001 SAS'd 4runner
Old Jul 25, 2006 | 06:00 PM
mastacox's Avatar
Originally Posted by 914runner
Going to be? It already is. I think its been done for over a month now.
Well, I suppose I'm waiting for the Petersen's to come out with pics of it in action...
Old Jul 25, 2006 | 06:27 PM
justinh's Avatar
Originally Posted by d0ubledown
that all pro 3link kit in a 3rd gen runner... bling bling
You might see one soon, I heard Gadget won the kit at TTORA Takeover last week!
Old Jul 25, 2006 | 06:47 PM
xcmountain80's Avatar
Originally Posted by JHupp
wow, that's sick! on a limited nonetheless
Thats awesome
Aaron
Old Jul 25, 2006 | 07:10 PM
SteveO's Avatar
nope...afaik, the earlier ones pre 00 i think dont have full time 4wd vsc atrac etc etc. schaefer & steveO's are pre 00...no? theres a local one here in vancouver thats sas'd. guy put fj80 axles up front..
Mine is a '99 Limited with the Multi-matic transfer case, which means, full time 4wd. In my rig, the speed sensor is the ABS sensor. Since I went to a Full float axle out back, I have no speed sensors at all. So, currently my speedo doesn't work, but the GPS does a great job. I also didn't have the VSC or ATRAC. But, since I did have the Full Time 4WD, I had to trick the computer into thinking that the front diff was engaged by opening the front diff switch. When I do this, and then put my lever into 4wd, the electronic acutator will allow the transfer case to go into 4hi and 4lo, thus giving power to the front driveshaft.
Scheafer's is a 4cyl, which has a different method of picking up the speed sensor (I believe it gets a signal from the transfer case tail houseing). Hence his comment about his last SAS on a 3rd Gen 3.4L, "it's wierd". The 4cyl is easier to sas than the 3.4L V6 4Runners.
Anyhow, he has a great rig there. I would say the next mod is protection. That front bumper needs to go.
Old Jul 25, 2006 | 08:58 PM
  #25
calrockx's Avatar
so...i could still have the first SAS'd 2002 4runner? yippidy doo!
Old Jul 25, 2006 | 09:04 PM
  #26
FUZION's Avatar
Old Jul 25, 2006 | 11:25 PM
  #27
deprunner's Avatar
pretty neet, looks like it was alot of work, also its forsale/
Old Jul 26, 2006 | 12:05 AM
  #28
rocket's Avatar
It makes me drool.
I love the front springs over axel.
Old Jul 26, 2006 | 05:29 AM
  #29
hlpressley's Avatar
Originally Posted by Rock Slide
For Sale?...which I had the cash for that!
$22K ? It is extremely nice but that seems a little steep.
Old Jul 26, 2006 | 05:40 AM
  #30
914runner's Avatar
22K is pretty normal for a '01 limited.
Old Jul 26, 2006 | 05:42 AM
  #31
Flygtenstein's Avatar
The trick is in the multimode cases. 4 or 6 cylinders doesn't matter. The speedo needs to be non-ABS dependant. This means anything up through 2000 that is not multi-mode.
I know it would be cool to retain all that stuff, but if you need a solid axle, you don't need ABS, VSC, ODB, etc. Having a working speedo would be killer though.
The UA just happened over the 4th. Coverage should be a couple months out.
That would not be a 22k truck stock. Once you hang an axle, it is a keeper or you get robbed.
Yeah, same truck.
Old Jul 26, 2006 | 07:14 AM
  #32
Rock Slide's Avatar
Wow, that FJ looks nice.
Ever since the new FJ has come out, that's all my wife has been talking about. She wants once so bad she can't stand it!
Old Jul 26, 2006 | 07:18 AM
  #33
BajaRunner's Avatar
I bet the Bentup crew did that one... Too close nearby and looks to be some nice work on that baby. (4runner)
Old Jul 26, 2006 | 07:22 AM
  #34
Crux's Avatar
Originally Posted by Flygtenstein
Are there any pics/videos of this thing wheeling?
Old Jul 26, 2006 | 08:49 AM
  #35
914runner's Avatar
I think theres more info about it on Pirate.
Old Jul 26, 2006 | 09:53 AM
  #36
No, it was a mix of mostly All Pro and some others.
I will post some more when I get home, but keep an eye out in the Mags this month.
Old Jul 26, 2006 | 10:00 AM
  #37
914runner's Avatar
Did you get to go on UA?
Old Jul 26, 2006 | 11:20 AM
  #38
cubuff4runner's Avatar
I had the speedo problem also because mine was abs dependent. I extended my rear abs sensors and hooked them back up on the rear and I have a speedometer again and no check engine light throwing the faulty speed sensor code.
Old Jul 26, 2006 | 11:26 AM
  #39
SteveO's Avatar
I would have done this, but since I no longer have rear ABS sensors (FROR Full Floater) I can't do this. Oh well, I'll get around to it and figure something out.....
Old Jul 26, 2006 | 11:41 AM
  #40
Some day I will probably do the full floated and be in the same situation.
