2000 Tacoma engine damage
Old Aug 30, 2021 | 12:40 PM
jehagado's Avatar
What caused this damage ?
What was g
nawing on the crank shaft ?
Old Aug 31, 2021 | 03:57 AM
aowRS's Avatar
Is that a 2.7 engine? Can you post a few more pics that would help others understand what it is that you are asking?
Andreas
Old Aug 31, 2021 | 04:23 AM
jehagado's Avatar
V6 engine, not sure what happened, I would like to know if anyone can explain.
Old Aug 31, 2021 | 04:27 AM
aowRS's Avatar
Can you post some pics that show the bigger picture?
Did you disassemble the engine or a shop?
Andreas
Old Aug 31, 2021 | 03:08 PM
jehagado's Avatar
Current owner took cover off engine, another photo.
Old Aug 31, 2021 | 03:17 PM
aowRS's Avatar
Sure doesn't look like the engine compartments of my two 3.4 V6 equipped 4Runners.....
I asked you if it was the 4 cylinder earlier since your first pic appeared to show a timing chain.
Andreas
Old Aug 31, 2021 | 06:03 PM
Jomoka's Avatar
That's the 2.7L 3RZFE motor. Not the V6.
It has two timing chains. One that runs the cams, and one that runs the balance shaft.
Not sure what would have chewed up the crank there, from the looks of it the crank pulley wasn't loose.
Was it running? If the cams seized the could shear the woodruff key and the cam drive sprocket would spin on the crank, but the motor wouldn't run.
falcondrgn
Jun 2, 2008 05:44 PM
leftcoastbill
Aug 26, 2007 09:23 AM
bamatoyoguy
7
Aug 23, 2004 09:29 AM
GoudyMan
Jan 21, 2004 11:59 AM
H-man
Aug 5, 2003 07:40 AM
