2000 4runner 4WD not engaging
Old Dec 4, 2008 | 07:09 AM
kaya4tmw's Avatar
I had this problem before and i took it to the toyota dealership. They said they freed things up and the 4wd started engaging again. Basically, I have the push button 4wd on my limited and the lights just keep flashing and will not shut off even if I push the button again. It feels like one side is locked and not the other. I would love to be able to free it up myself but not sure how. Any help would be greatly appreciated. Thanks!
Old Dec 4, 2008 | 07:29 AM
cackalak han's Avatar
1st, have you tried driving back and forth, even turning the steering wheel while doing so? Hopefully, it's just needs a bit of prodding to get it going again. Otherwise, it could be a vacuum leak, solenoid/actuator, wiring, etc.
You need to engage the 4WD system at least once a month for a few miles to keep it lubricated right.
Old Dec 4, 2008 | 07:57 AM
kaya4tmw's Avatar
Cackalak--thank you for your reply. I haven't had much of a chance to drive back and forth and turn the wheel while doing so but I will certainly try. I had been engaging it on occasion but I do believe I had not in a few months. I am feel like it is nothing more than stuck as the same thing happened before but maybe I am just having wishful thoughts. Thanks again for your help. Does anyone know how I could manually try to get it freed up if above suggestion does not work out?
Old Dec 4, 2008 | 09:17 AM
Punch's Avatar
You may have a common problem like myself and others. The good news is, it can be fixed for under $50 bucks;
https://www.yotatech.com/forums/f2/4...er-ltd-131201/
mskalmus
May 28, 2017 07:51 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Avenged
Jul 9, 2015 07:55 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
