200,000 mile club!!
Old May 1, 2011 | 12:29 AM
  #181
00toytaco's Avatar
2000 Tacoma V6 5VZFE motor 4x4 200,262 miles so far I've replaced both struts and shocks and right now the power steering rack and pinion, struts, and water pump are out.
Old May 1, 2011 | 09:00 AM
  #182
bobby_duce's Avatar
wow thats alot of miles for a 11 year old truck.
Old May 2, 2011 | 05:31 AM
  #183
00toytaco's Avatar
hell yeah the the longest its sat is right now cause it needs tlc but most of those miles are 4 wheeling...gotta love the mountains
Old May 2, 2011 | 04:20 PM
  #184
Bandido's Avatar
1994 pickup 203k.... was worried and confused when the distributor went, but figured it out and it is still running great!!
Old Jun 13, 2011 | 05:51 AM
  #185
Dave7074's Avatar
1999 4Runner Highlander, 218,000. Although starting to get some evidence of a slight head gasket leak, so our days may be numbered.
Old Jun 14, 2011 | 03:40 PM
  #186
Vargntucson's Avatar
The last time I checked I was at 207K and still running strong
Old Jun 14, 2011 | 06:25 PM
  #187
85gijunk4x4's Avatar
88 pickup 3vz. 243,xxx and runs like a champ
85 pickup 22re, 223,xxx (pretty low compared to others) and, well...it has its problems LOL
Old Jun 17, 2011 | 05:57 PM
  #188
quicksilvr's Avatar
My sisters 1997 Limited just rolled over 242K. Runs amazing, last weekend she averaged 20mpg on a canoe trip to south Missouri. Engine only seems to burn about 1/2 quart of oil every 3000 miles.
Old Jun 17, 2011 | 06:42 PM
  #189
kleen894WD's Avatar
'89 DLX 22re 208,000 n climbin'--- not very demanding---mebbe a sip of dinosaur juice every 1,800 miles--- turn the key and go
Old Jun 28, 2011 | 04:54 PM
  #190
kdx2000's Avatar
I have 99' Limited with 261800 miles and still going strong. The right side valve cover is leaking a little and the front end sounds like possibily the ball joints or someting is making a metal on metal contact sound. All suspension components are original. It maybe time for upgrades.
Old Jun 28, 2011 | 05:01 PM
  #191
BoredOutnJackdUp's Avatar
205k and doesnt burn a drop.
Old Jul 1, 2011 | 08:11 PM
  #192
pba123's Avatar
2000 Tacoma 2wd, 5sp - 451,000 miles
Old Jul 1, 2011 | 08:58 PM
  #193
Teuf's Avatar
451 k, now we are talking milage. Good one.
Old Jul 2, 2011 | 07:01 AM
  #194
Ian Rogers's Avatar
I am 350 miles away from the 200K club. Sometime next week i should cross over. 2000 4-runner 5 speed, supercharged.
Old Jul 3, 2011 | 02:35 PM
  #195
cdre's Avatar
206k '96 Limited. Just did front brakes, struts, shocks, and replaced original radiator (and installed aux trans cooler). Replaced starter contacts on it once, and rear axle bearings when my sister let the diff run low. Other than that, timing belts, oil pump and water pump around 30k ago.... No complaints. Drove from Phoenix to Virginia earlier this year and averaged 19mpg. Once I replace the bottom seat leather in the driver seat, it'll be good as new.
Old Jul 3, 2011 | 04:07 PM
  #196
phildelfino's Avatar
Memorial Weekend.
Old Jul 6, 2011 | 06:09 AM
  #197
Potomacduck's Avatar
310K daily driver.
Old Jul 6, 2011 | 01:03 PM
  #198
Deuxroues's Avatar
1999 Limited - 210,000 miles
Doesn't leak a drop or smoke! Runs strong, smooth, doesn't shake and tows my 20' trailer very well.
Have replaced shocks, struts, steering rack bushings, steering rack guide with newer style non roller bearing type, sway bar bushing, 2 timing belts and water pumps, re-geared front and rear differentials to 4.56, front ARB air locker (came stock with rear e-locker), on board air tank and air compressor with on the console air gauge, rear air bags (for towing), transmission oil cooler, third brake light LED cluster mod, Tundra 233mm brake calipers, EBC dimpled and slotted rotors, EBC yellowstuff brake pads, running boards removed and 18" KMC wheels with my own custom designed TRD center caps.
Old Jul 11, 2011 | 05:25 PM
  #199
thom134's Avatar
New here but just went over 200k in my '94 ... looking forward to many more.
Old Jul 12, 2011 | 08:10 PM
  #200
Ian Rogers's Avatar
Just made it
Wow, i was crossing to Golden Gate Bridge and noticed I was 2 miles away from 200K. so i took a pic its worth a 100o words. Love my two Toyota's !!!!
