2 new radiators failed in 4 months... any suggestions?
Old Jul 27, 2005 | 05:51 AM
2ToyGuy's Avatar
Originally Posted by callmej75
Don't know if this is a silly question...but would a 80% stopped up catalytic converter make the system over pressurize?
I don't see how it could, but I'm a Radar tech, not a mechanic. I don't see any way for the exhaust to get into the radiator, unless the hg is leaking it there. And then, once again, the cap SHOULD releive any pressure above 13.5 PSI, or 15, if you have a hi-pressure cap on. Either way, it shouldn't be able to blow the radiator. If the cap is bad, on the other hand, and you DO have a HG leak, well there you go...
Old Jul 27, 2005 | 05:54 AM
callmej75's Avatar
Yeh I was trying to find the link there between exhaust and coolant but was unable to...just a shot in the dark
YotaJunky's Avatar
Originally Posted by Slowrunner
Where did you buy it and how much?
Got it from Performance Radiators in Coquitlam, just off United Blvd. Lists for $288 CDN. I got mine for $210 because I know someone at a Toyota dealership who referred me to them.
Troy
Old Jul 27, 2005 | 05:55 AM
YotaJunky's Avatar
Originally Posted by 2ToyGuy
I wish you good fortune with this radiator! Keep us posted. I would guess that if it fails again, you MAY have another, underlaying problem.
The hg can overpressurize the radiator by permitting exhaust or even just compression past the hg and into the water jacket. On the other hand, the cap should permit the excess pressure to vent off before it damages the radiator. I would have replaced the radiator cap BEFORE the hg...
The radiator cap was not the problem, because I replaced them twice with new caps.
Troy
Old Jul 27, 2005 | 06:06 AM
  #25
2ToyGuy's Avatar
Ok, just trying to cover all possibilities. You never know...
Old Jul 27, 2005 | 06:09 AM
  #26
YotaJunky's Avatar
Thanks for your input. These forums are all about helping each other and letting off steam when it get's a liitle too hot, either under the hood or under the collar. Many thanks to you and all the other posters. If it weren't for this forum, I wouldn't enjoy wrenching as much as I do now.
Troy
  #27
callmej75's Avatar
Its that high output 3.0 just blowin the tops off the radiators
Old Jul 27, 2005 | 06:29 AM
  #28
YotaJunky's Avatar
ROTFLMAO!!!
Troy
Old Jul 29, 2005 | 05:41 AM
  #29
YotaJunky's Avatar
replaced my rad. Fingers crossed for no more rad problems....
Troy
Old Jul 29, 2005 | 03:15 PM
  #30
CoedNaked's Avatar
Hey Troy,
I just had my oem rad replaced (had a very very small pinhole leak - nothing major but I don't like having doubts in the back of my head) with a performce radiator on my 3vze as well a month ago. Got it through Langley Toyota town.
Scott
Blamalam
Mar 12, 2022 07:34 AM
JaredL
Mar 28, 2016 09:08 PM
Road Bull
Oct 10, 2015 04:55 PM
this_guy
Aug 10, 2015 10:44 AM
TJWilly
Jul 31, 2015 02:05 PM
