2.7 owners check your oilpans for rust
Old Apr 13, 2012 | 01:23 PM
Rich's Toy's Avatar
Welded on extended sump (factory) has rusted through at the weld and is leaking oil. More fun and games I guess.
Attached Thumbnails 2.7 owners check your oilpans for rust-rusted-out-oil-pan-001.jpg   2.7 owners check your oilpans for rust-rusted-out-oil-pan-003.jpg   2.7 owners check your oilpans for rust-rusted-out-oil-pan-002.jpg
Old Apr 13, 2012 | 03:22 PM
jmfranc's Avatar
Wow. Mine looks like new. I guess it's the coating of oil that's been on there for 13 years.
Old Apr 13, 2012 | 03:30 PM
snobdds's Avatar
liquid brine does that...
Old Apr 14, 2012 | 07:02 AM
Rich's Toy's Avatar
Yea that road salt is brutal... Just seems like a strange place
for rust perforation.
Old Feb 13, 2014 | 09:23 AM
budget76's Avatar
Yes I had the same problem. I have a complete write up on repair (not replacement) in the works with pictures, but for those of you who need know now.
drain oil. (save for re-use if good)
remove mud, oil, and rust and wire brush leak areas .
use brake cleaner for final cleaning
use JB WELD (lots of it) to create vacum seal around area
use por-15 once don to paint remainder of rust area not covered in JBWeld
paint with rustoleum black (or your favorite color) to make all air tight. Two thin coats are better than one thick.
now you have encapsulated the rust, filled the holes, and prevented air from causing more rust.
Put oil in engine and you have engine oil above rust preventing air from reaching rust area.
So far 16 months works fine.
cost $6. Would have replaced, but dropping the front-end ona 98 Tacoma is a PITA**PITA.
Old Feb 13, 2014 | 09:25 AM
budget76's Avatar
Oh forgot, if you are still concerned, spray oil and grease around the bottom 1/2 of your engine.
Old Feb 16, 2014 | 03:09 PM
wyoming9's Avatar
Red face
What kind of prep work did you do and what kind of paint??
Did you do the welding or someone else??
nanhodges2733
May 29, 2020 03:28 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 13, 2015 10:57 AM
