2.5" Cornfed + OME
Old Aug 12, 2004 | 01:57 PM
BajaRunner's Avatar
2.5" Cornfed + OME
Its been about 2 months since I installed my OME suspension lift. The rear is great, giving me around 3". However, the front has been a good 2" lower ever since installing.
A few weeks after seeing this, I decided to get a 1.5" daystar spacer to help things out. Well, It added about 1". Im still at least 1.5" lower in the front. It just really bugs me to look at my 'runner and see this.
So, last night I ordered the 2.5" cornfed front spacers to finally remedy my situation. Id personally rather be .5" higher in the front than in the back.
Sooo...Question is, since my lift didn't really work for me in the front, I'll be okay with installing this on top of my OME springs, right? Currently, with my 1" diff drop spacer installed, my CV boot "fins" aren't touching. Im hoping this will work out for me.
My other concern was travel. Since this spacer is in the pack, I wont be adding more droop, will I?
Is there anything else I should be concerned about?
Old Aug 12, 2004 | 02:14 PM
User 051420's Avatar
Glad to see I'm not the only one complainng about OME sagging. Have you thought about using Revtek top out extenders in combination with other spacers?
Old Aug 12, 2004 | 03:53 PM
BajaRunner's Avatar
I haven't thought about it really... I just wanted to stick the cornfeds on because I wont have to worry about sagging for a while.
Old Aug 12, 2004 | 04:50 PM
spiff's Avatar
Which OME shocks and coils do you have?
Old Aug 12, 2004 | 04:53 PM
turboale's Avatar
mine sagged with the tjm majorly.... still are saggin a little with the Downeys... I need to see if I can crank 'em a little. Though, I'm still on my original CVs so, i'm not complaining too much
You could call up Roger Brown and get a custom body lift with a .5 or 1.5 in the front and 1" or 2" in the rear.
ZGjethro
Jun 7, 2017 11:04 PM
Scottcrb
Mar 3, 2016 11:57 AM
A2theK
Oct 14, 2015 07:10 AM
Swampwalker
Oct 12, 2015 09:49 AM
justdifferentials
Sep 5, 2015 06:52 PM
