1st Gen Lower Valence...
Will all the lower valences that were installed on toyota trucks from 84-88 fit each other. Example: An 88 4Runner valence fitting an 86 Pickup? The reason I ask is because after seeing CDUFF7s lower valence vs. my wimpy lower valence, I knew I needed something better. As that mine is a street truck, I'm looking for the largest valence possible (within reason
). I like the size and look of CDDUFF7s. Does anyone know if that lower valence will fit my truck? It looks like the mounting holes are the same, just not sure.
I have this lower valence: (86 pickup 2WD)
And then there's this lower valence: (86 pickup 4WD)
The 2nd one appears to be somewhat larger, and is for a 4WD, but the 88 Hilux Surf looks much different, and a lot bigger. Thanks for any help.
). I like the size and look of CDDUFF7s. Does anyone know if that lower valence will fit my truck? It looks like the mounting holes are the same, just not sure. I have this lower valence: (86 pickup 2WD)
vanion2
Jul 29, 2015 06:17 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
Jul 6, 2015 04:07 AM
