1999 4runner "Walks" Down The Road
Old Apr 22, 2009 | 09:07 PM
Smallwood0507's Avatar
Originally Posted by Gerdo
Replace them with poly bushings. It will feel loose and wander even without hitting bumps. Grooves in the pavement and truck humps will make it really swim.
What tire are you driving? I had a set of Bigfoot AT Dual Grooves. They were horid! The truck would walk/swim/float or what ever you want to call it all over the road. Sometimes it was down right scarry. You always had HANG onto the steering wheel. I replaced them and it is a different truck. (the bushings also help, I did them first but it was still bad)
Are you talking about the steering rack bushings. Im just running Goodyear p265 nothing special tires.
Old Oct 11, 2009 | 10:35 AM
Thought id let you guys know that i ended up replacing the bushings with new ones off wheelers a while ago and totally fixed the problem. thanks for the help
Old Oct 14, 2009 | 12:45 PM
ywokchile's Avatar
great! can you recommend the exact part name, brand, where you got them?
there wasn't any clicking in the steering going on before?
I had something similar in my 2001 model, and it's bl#@dy annoying
it tracks pretty straight on good roads, but a sharp pot hole will make it sound like a click, and it can move about slightly at speed with bad roads.
Old Oct 14, 2009 | 07:25 PM
sorry no clicking but to see if your steering racks bad have sameone move the steering wheel back and forth while you see if the rack moves AT ALL if it does their shot.
the link to the bushings is http://www.wheelersoffroad.com/4runnerrackbushkit.htm
Old Oct 26, 2009 | 12:15 PM
  #25
hurricanes99's Avatar
I have recently started getting that "side to side" feeling at highway speeds, but mine only occurs when I am close to a 18 wheeler. I guess the air flow from the truck is causing the 4Runner to become unstable. For those of you who have replaced your bushings in the steering rack is it a easy diy job or better left to a trained mechanic? My 4Runner is a 99 4x4 with 130K miles. I just had the sway bar end links replaced on both front sides. I very rarely take this vehicle off road...
Old Oct 26, 2009 | 01:35 PM
  #26
From what ive read it is i didnt have a garage to do mine in so i took it to a mechanic....But i would say thats probably it especially if you check to movement of the rack while someone moves the steering wheels back and forth
Old Oct 26, 2009 | 05:59 PM
  #27
What kind of price should I expect to pay for a mechanic to do the work? Thanks.
Old Oct 26, 2009 | 06:36 PM
  #28
Mine was from our family mechanic and he charged me $100 would have been $150-$200 for anyone else....the bushings only cost $26 with shipping from wheelers so if you are able to do it yourself it would be worth it. you can look up the install and see what you think. to me it looks easy but i just didnt have anywhere to do it.
Old Oct 27, 2009 | 09:31 AM
  #29
Pikeman's Avatar
There are a few threads on here on install that are pretty in depth. I have the bushings sitting on my counter at home and yes it is a Half day job for the DIYer and about an hour or two labor for a skilled mechanic. I am just waiting for my sway bar end links and bushings to get here so I can take care of all of it at the same time.
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
redneck17
Jul 17, 2015 07:44 PM
cyclist231
Jul 7, 2015 12:56 PM
