1999 4runner Transmission/t-case compatibility
Old Dec 21, 2007 | 03:32 PM
YotaFun's Avatar
I think the general concensus is that he has the J-pattern shifter.
I was not aware that the push button j-shift was ever an option on the 99-00 highlander edition. If so it was not a standard option and had to be specail ordered.
Hence why we are ruling out the push button t-case options all together.
And wouldn't you think by now that Mr. Justinh would have stated if he had a button or not since that seems to be what we have focused this thread around?
If not please inform me when the topic changed to specail order 4Runners, I would be glad to start a seperate thread on the topic!
Old Dec 21, 2007 | 04:03 PM
DeathCougar's Avatar
Im not saying anything about special order trucks. I am merely throwing out all the possibilities. better to be over prepared than under prepared I always say.
Old Dec 21, 2007 | 04:11 PM
sportlocked's Avatar
throwing out all the possibilities? i understand you are trying to "guess" at this, but the answer is no, their was never a push button j , straight shift, dash board whatever transfer case in a highlander.
ive driven 10 and i know 20 others that have highlanders that would say they have J shift chain driven, non push button tcase in their 4runner.
Old Dec 21, 2007 | 04:47 PM
YotaFun's Avatar
I agree it is better to be prepared then sitting in you chair bangin your head with a keyboard cause you prdered the wrong part.
But statisticlly all the highlander models came with the J-shift pattern t-case unless it was speacil order, which is highly unlikly since its rare to do to begin with.
Even when searching through eBay and Craigslist, I have never come across a highlander edition in 99-00 to have the push button j-shifter, if you can find evidence of a 99-00 Highlander Edition with the push button j-shift case, please do share.
Old Dec 21, 2007 | 09:00 PM
  #25
KZN185W's Avatar
the J-shift pattern does not need a separate switch for the center diff lock because the center diff is locked when you move the transfer lever into H4L or L4L and unlocked when you go into H2 or H4.
Old Dec 22, 2007 | 03:51 AM
  #26
YotaFun's Avatar
Correct the Push Button J-Shifter does not have a center diff lock button.
The way this shifter functions is.
1) Press Button All-Wheel Drive Engages
2) Pull back on shifter, Lock center differential into Four Wheel Drive High.
3) Shift Auto Transmission Into Neutral, Then Push Stick over and up Into Neutral then Four Wheel Drive Low.
4) Reverse Steps 1-3 to get back into Two Wheel Drive High
Old Dec 23, 2007 | 01:47 AM
  #27
KZN185W's Avatar
OT:
ONLY
the 99-00 LIMITED runners had the push-button j pattern shifter like so:
Yotafun,
Would you happen to know the specific part number for this j-shifter "Shift Lever Knob Sub-Assembly"?
Thanks.
Old Dec 23, 2007 | 03:51 AM
  #28
rocket's Avatar
This thread began as a good and informative discussion but quickly turned into a lot of insults and impersonal differences.
To be fair to everyone, i deleted all of the posts that contained attacks and/or statements that added to the chaos.
Hash it out all you want, but don't turn it into personal matters.
If you wish to continue, please stay ON TOPIC.
Old Dec 23, 2007 | 08:14 AM
  #29
YotaFun's Avatar
OT:
ONLY
Yotafun,
Thanks.
I do not know off hand but I can look into it for you.
Old Dec 24, 2007 | 05:51 AM
  #30
KZN185W's Avatar
Thanks!!
Appreciate it!
Merry Christmas to everyone!!
Old Mar 4, 2011 | 04:17 PM
  #31
ttq02's Avatar
I have 1999 4 Runner Limited when you press the brake can't ship to drive
Old Mar 4, 2011 | 09:10 PM
  #32
ttq02's Avatar
1999 4 Runner shift stuck in park
Old Mar 4, 2011 | 10:57 PM
  #33
I am confused by the second of your posts?
Old Mar 5, 2011 | 12:53 PM
  #34
Texas_Ace's Avatar
I think he is saying there is something wrong with the brake lockout on the shifter and he can't get it out of park.
I had this happen to my truck soon after i got it, i just used the white button/leaver override switch at the top right corner of the shifter base to override it.
After i did that it worked fine from then on. No idea what caused it.
You might need a flat head screw driver to get to the switch, you want to push it either forward or backwards, i think backward.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
cyclist231
Jul 7, 2015 12:56 PM
