1996 Tacoma problem with clutch
Old Dec 9, 2008 | 08:10 PM
moaky's Avatar
I have to push really hard on the clutch to start the truck. All the way back plus some. If you know whats up I would appreciate the info. I was going to check the fluid but i couldnt figure out what reservoir was it. I know there is the brake res and the clutch res next to each other. I thought it my be a good idea to bleed but i dont know how. Any tips. Thank you for your time.
Last edited by moaky; Dec 9, 2008 at 08:16 PM. Reason: thread needed more information
Old Dec 9, 2008 | 09:36 PM
One_96TR4's Avatar
Its not the resevoir, it's the pedal itself. For whatever reason its not hitting the clutch switch. I Mine does the exact same thing. I usually start it with the clutch cancel so it doesn't bug me. If you want to fix it, look under he dash and there's a little plastic clip that snaps into the pedal that when pushed depresses the clutch switch. Just put a longer clip in so it hits the switch sooner. I don't know if I'm making any sense. Just look at the pedal itself and push it with your hand while your under the dash, You'll see what I'm talking about.
smthwsn357
May 1, 2024 07:28 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
Poncho0206
Jul 10, 2015 06:21 PM
Yotoder865
Jul 9, 2015 07:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
