1996 t100 tacoma 2.7l Cranks, but no start please help.
Old Jun 15, 2016 | 11:15 AM
charlesadcox's Avatar
I have a 1996 tacoma with a 2.7l efi with a distributor. It will crank but no start. The engine has no spark. It has voltage going into the distributor and crankshaft signal pulse to the distributor. I replace the distributor with rebuilt as I have in the past with other yoters, but no spark condition continued. I have since changed the ignition module, crankshaft sensor and ecm with know working part. but still have no spark. I have checked continuity on all electric lines with no brakes in the wires and nothing seems to be shorting out. Any suggestions?
Old Jun 15, 2016 | 12:27 PM
tantacoma's Avatar
Do you have an old aftermarket alarm system? If so, remove it. With the no-start anti-theft function, they are notorious for causing problems with owners down the road.
Old Jun 15, 2016 | 12:52 PM
no aftermarket anything on this truck.
Old Jun 15, 2016 | 04:21 PM
tantacoma's Avatar
Do these motors have only one coil?
Old Jun 16, 2016 | 11:23 AM
TheDurk's Avatar
First is to remove the high voltage coil wire from the distributor center post and hold it about 1/4" from the block and see if you get a nice spark when you crank. If you do, swap rotor and cap. If not, check points and condenser or just swap them. Disclaimer: Never seen a distributor Toyota but I know my dizzies.
redrum757
Domestic Swaps
Mar 6, 2016 02:23 PM
bigmumbles69
Feb 29, 2016 08:05 AM
FRANCOARMANI
Feb 18, 2016 07:04 AM
83danimal
Jan 31, 2016 11:26 AM
