1994 3.0 engine removal tips
Old Mar 2, 2004 | 05:43 PM
gila4runner's Avatar
Hello,
I came across a 1994 4runner (3.0 V6)that hydro locked and broke some rods.
It's head gasket had blown.
I have almost removed the motor. The top two bolts that hold the transmision and engine together seem impossible to access.
Should I remove the engine and transmision together?
Does anybody have a step by step guide?
It blows my mind how tight some of these bolts are. Seems like it was designed for a 4 cyl.
Help
Thanks
Old Mar 2, 2004 | 05:58 PM
lunatic14r's Avatar
do you mean the bell housing bolts????
Old Mar 2, 2004 | 06:01 PM
Yes the bell housing bolts. Does anybody have a step by step guide.
Thanks
Hank
Old Mar 2, 2004 | 06:25 PM
Designsbyme's Avatar
I'm doing the same thing you are. The trans does have to come out. Here is a book.
http://www.delmarlearning.com/Browse...SBN=0801986826
My thread...
https://www.yotatech.com/forums/f2/new-engine-yes-no-27779/
Old Mar 2, 2004 | 06:48 PM
oly884's Avatar
Guest
It takes some extensions and some tiny wrists (i got lucky with both). It's not fun, but it's MUCH eaiser to remove just the motor instead of both the tranny and motor. There isn't much room to pull out both.
Old Mar 2, 2004 | 07:19 PM
Does it help to remove the motor mount brackets and lower the motor with a jack?
I was also thinking about removing the heads then the rest of the motor.
Where is the best place to buy a rebuilt 3.0. Does anyone know of a good machine shop in Seattle? I think my core is bad.
Thanks
Hank
Old Mar 2, 2004 | 07:26 PM
Thanks
Hank
These people have the best warranty I’ve seen. http://www.powerpro2000.com/long_block_engines.htm I have looked all over the place. You should try to PM BruceTS, he just finished replacing his engine and he has done it several times.
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Road Bull
Oct 10, 2015 04:55 PM
Roger Borba II
Jul 9, 2015 05:05 PM
ItsJustD
Jul 7, 2015 07:49 AM
