1993 V6 Tranny Shifting Question
Old Feb 17, 2004 | 12:30 PM
npb4me's Avatar
My automatic tranny shifts right through 3rd gear. Will not stay in 3rd at all no matter if I am cruising or under full throttle? Any ideas why?
Thanks!!
Old Feb 17, 2004 | 03:26 PM
Transdude's Avatar
Thanks!!
Are all of the other shifts ok? Is the 1-2 shift at the proper time? Does it basically shift from 2 to 4?
-John
Old Feb 18, 2004 | 09:37 AM
npb4me's Avatar
It shifts good from 1-2, then into 3rd for a very short time and then it goes right into 4th. So, I basically hit high revs in 2nd, then when it goes through 3rd into 4th, I am at low revs. And I have little power in 4th at the low revs I am at.
Old Feb 18, 2004 | 09:55 AM
Transdude's Avatar
It sounds as if you may have a worn valve body / clogged shift solenoid situation.
-John
Old Feb 18, 2004 | 09:58 AM
npb4me's Avatar
-John
Is this going to be expensive to have checked and fixed?
Old Feb 18, 2004 | 01:56 PM
Babypig's Avatar
I would pull the codes for the trans(same as the engine) and go from there. Also check the fluid(small thing but often overlooked). Once you get a code we can definitley help point you in the right direction. Let us know what code you get. Also let us know what engine trans combo you have so we have more info to go on.
Old Feb 18, 2004 | 04:37 PM
Transdude's Avatar
Not cheap.
Keep in mind I'm also shooting from the hip here, based on my past experience. It is difficult to diagnose a transmission with 100% accuracy without actually having it at my shop and driving it.
-John
ladybugRC
458
Aug 21, 2020 10:41 AM
JNapolitano
Nov 14, 2019 07:46 PM
mistershmi
Aug 31, 2015 03:44 PM
norcal98
Aug 10, 2015 06:20 AM
PlayAwhile
Jul 20, 2015 11:36 AM
