17 or 16 tires
Old Jul 2, 2004 | 02:36 PM
rayh78's Avatar
17 or 16 tires
Hope someone can give a little advice
Have a 2000 tundra with 16" plain wheels and would like to replace with 17inch wheels from a 4runner sport 2003. Should I have any problems?
Or is this a good idea? thanks
Old Jul 2, 2004 | 03:07 PM
4RunnerFever's Avatar
Sounds like a great idea. You shouldn't have any problems. Hopefully others will chime in.
Old Jul 2, 2004 | 09:09 PM
bulldog-yota's Avatar
You shouldn't have any issues in terms of the wheels fitting, however check the load rating on the tires vs what you do with the Tundra.
There is not a lot of LT rated 17" tires, which will limit the ability for the Tundra to carry weight. SO just check.
Old Jul 2, 2004 | 09:10 PM
Good Times's Avatar
Aren't the offset different and the BS? I thought that the 4th gen wheels didn't fit the Tundra's?
That was my understanding... I could be wrong. Might want to test fit them to ensure proper fitment prior to buying.
Old Jul 2, 2004 | 09:13 PM
Apparently some guys fit the Sequia wheels on their Runners, and I assume the Tundra and sequia (can never get the spelling corret) are the same. But valid points, so do a test fit and also a weight rating check.
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
