15"s instead of 16's
Old Oct 28, 2007 | 05:34 PM
nickxrunner's Avatar
I have a friend that recently purchased some 15's from a 00 tacoma and wanted to install them on his 96 4runnrer. The problem is the 4runner came with 16"s from the factory. He just called and told me they wont fit on the front but will on the rear. Could anyone tell me why and is there something I could do to make them fit.
Old Oct 28, 2007 | 05:35 PM
OSU4Runner's Avatar
15's wont fit over the front brake rotors....I don't think there is anything you can do about it.........not sure though......maybe someone else will chime in
Old Oct 28, 2007 | 06:14 PM
LJ_24's Avatar
it wont work...I called toyota about this cuz i wanted to do the same thing...they said if your 4runner came with 16's...that means it has larger disk brakes.
Old Oct 28, 2007 | 07:06 PM
d0ubledown's Avatar
...unless they were swapped from 15's to 16's somewhere along the way...
Old Oct 29, 2007 | 05:38 AM
blarchitect's Avatar
If the sticker on the drivers door slam panel states 16" they won't fit.
Old Oct 29, 2007 | 07:17 AM
OSU4Runner's Avatar
You got screwed!
Old Oct 29, 2007 | 06:31 PM
Someone on another site was saying that I could grind some off the top of the rotor and a little alone the round shield next to the rotor and it should clear. Has anyone else heard about this?
Old Oct 29, 2007 | 06:34 PM
Originally Posted by OSU4Runner
You got screwed!
Nah Not Me! He might have, but from what Im reading on other sites... there maybe a chance after all.
Old Oct 29, 2007 | 06:51 PM
CJM's Avatar
CJM
Do not grind any part of the brakes!
Old Oct 30, 2007 | 05:39 AM
You don't want to compromise safety for aesthetics.
Old Oct 30, 2007 | 05:45 AM
04 Rocko Taco's Avatar
If anything you would grind the CALIPER, not the rotor, but the fluid passages areVERY near the surface in the Runner calipers, and you cannot remove enough material to clear the wheels, and still maintain pressure integrity inside the caliper. Complete crap idea.
Stick with the 16" wheels.
Old Oct 30, 2007 | 12:15 PM
OSU4Runner's Avatar
x2!! Or you'll be your brakes down the toilet
