$129 Supercharger!!
Old Oct 30, 2004 | 06:22 PM
User 051420's Avatar
$129 Supercharger!!
http://cgi.ebay.com/ebaymotors/ws/eB...category=46098
What a bargain!!! 250 cfm of Compressed Air Moving Power!!!!
Old Oct 30, 2004 | 06:33 PM
yotafreakshow's Avatar
Looks like someone fitted a filter onto a hair dryer.
Old Oct 30, 2004 | 06:36 PM
TACOMANATOR's Avatar
Ha,hahahaha what a joke. I bet they sell the crap out of those to all the ricers.
Old Oct 30, 2004 | 06:44 PM
kyle_22r's Avatar
my carb flows more than 250cfm
is that a hair dryer?
Old Oct 30, 2004 | 06:52 PM
914runner's Avatar
I saw that on eBay a couple days ago and just started LMFAO!
Old Oct 30, 2004 | 07:38 PM
mike_d's Avatar
yeah, a turbo of about the same size needs to spin at 100,000 rpm or more to pump enough air. i'm sure that some cheap plastic fans can't spin that fast.
let's do a little math:
3.0 L engine at 3,000 rpm = 9,000 L/min of air
9,000 L/min = 9,000,000 cc/min = 550,000 cin/min = 320 cfm
and that's only at 3,000 rpm. it's twice that at redline.
let's say you wanted 2 pounds of boost. that's an increase from 15psi to 17psi,or 13%
so to add 2 pounds of boost you'd need somewhere near 360-370 cfm
i can't believe that these people can get away with selling such crap.
what i'd love to do is actually run a roots blower from a supercharger by a switched electric motor. that way you can have boost when you want it and no drag when you don't. you'd probably have to run a beefier alternator to be able to run enough current to a motor to pump enough air, but at least when you have the motor off, there'd be negligable drag.
Old Oct 30, 2004 | 07:42 PM
toy283's Avatar
Your math is off a by a factor of two right there. Considering that a 3.0 Toyota engine is a four-stroke engine, it takes two revolutions to draw 3.0 liters of air. So your first line should be:
3.0 L engine at 3,000 rpm = 4,500 L/min of air
Old Oct 30, 2004 | 07:52 PM
toy283's Avatar
Huh??? If the roots type blower is still in the airflow, it will heavily restrict airflow through it if it's not turning. Roots type rotors are designed to have very tight tolerances to their housing, if they aren't turning very little air can get by. Now I have seen something like this done using two superchargers. Visualize a 454 Chev with two small B&M superchargers mounted side-by-side on a custom pent-roof intake manifold. Each supercharger has a pair of small 4-barrel carbs. One supercharger is belt driven from the crank and runs all the time. The other is driven using an air conditioning style magnetic clutch and can be turned on when wanted.
Old Oct 31, 2004 | 05:38 AM
yamarocket630's Avatar
If you want to get really technical, it's off by more that that, as no normally aspirated engien that I know of is capable of 100% volumetric efficiency. It would be reduced by another 20-35%.
Old Oct 31, 2004 | 08:46 AM
toy283's Avatar
Very true. At idle, a N/A engine "might" see 90% and it goes downhill from there to as low as 60% at redline. Usually VE reaches "best case" right about the torque peak of the power curve. After that, it drops off and so does torque/power.
Old Oct 31, 2004 | 11:27 AM
Ontos's Avatar
Decided that the supercharger looked like quite a bargin, so I shelled out the bucks and went ahead with the install. It was pretty cool, LOTS more power, inclused a "master intall kit" for FREE.....and even threw in a FREE BLOCK HEATER!!!
Check the pics after install.
http://img67.exs.cx/img67/7896/supercharger.jpg
Here's the block heater before it went in...
http://img86.exs.cx/img86/6033/blockheater.jpg
Now I need one of those big Honda Civic wings to keep the rear tires on the ground at speed.
Old Oct 31, 2004 | 11:30 AM
ctcost's Avatar
Pays to read the fine print before bidding eh?
Old Nov 1, 2004 | 04:23 AM
Ilovemountains's Avatar
Haaaaaaa!
Thats a good one! Haa, I bet my neighbors kid with the loud Honda already has one. I walked over there one day just to say hi and take a look under his hood, what a joke! blue vacuum lines, a Tornado intake thing, fake K&N filter setup, a $7 ebay strut brace that looked like a peice of all thread, the car has cut stock springs, and a very loud muffler big 18" cheap wheels, red calipers the words Limited on the doors and the list goes on! The bad thing is it was a really nice car when he bought it, a 99 Accord V6! Bling Bling yo, its a race car now... I love smoking him through the twisties in my Miata hell my 88 3.0 could beat him on these back roads
Steven.m.paulk
Jun 7, 2020 10:45 AM
LCE_Performance
Oct 1, 2015 01:03 PM
anniesball
10
Sep 15, 2015 05:41 PM
anniesball
Sep 9, 2015 09:55 AM
anniesball
Sep 7, 2015 11:20 AM
